List Your Mods: |
Post Reply | Page <1 4950515253 77> |
mtbmitch
Groupie Joined: 15 Sep 2013 Location: Boise, idaho Online Status: Offline Posts: 91 |
Topic: List Your Mods: Posted: 05 Aug 2014 at 11:44am |
I drive down a lot of dirt roads and suggest that you might replace the screws that attach the hinges to larger doors with some bigger screws. The stock stuff is might be ok for smooth pavement but falls out on washboard or rough roads.
enjoy the fresh air
ANGCHIEF
Groupie Joined: 18 Oct 2013 Location: Michigan Online Status: Offline Posts: 55 |
Post Options Quote Reply Posted: 04 Aug 2014 at 4:59pm |
We just got back from Alaska - don't forget blackout material for the windows, at least the ones next to the bed. It still stays pretty light up there! I used thin blue foam insulating sheets and cut them to fit the windows. Worked great. Have a wonderful trip! Our Pod did GREAT!!
Jan and Dean
2014 178 |
ShazG
Newbie Joined: 25 Mar 2014 Location: Wallsburg, Utah Online Status: Offline Posts: 9 |
Post Options Quote Reply Posted: 04 Aug 2014 at 2:20pm |
http://www.amazon.com/gp/product/B002UC6RP8/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1This is where I got mine. Amazon. Perfect fit.
ShazG
Tbslants
Newbie Joined: 12 Jul 2014 Location: Brunswick, ME Online Status: Offline Posts: 10 |
Post Options Quote Reply Posted: 04 Aug 2014 at 2:01pm |
Hi TriumphRider,
I recently purchased the 179 and have the same issue with the TV...the links for the mod would be greatly appreciated. Thanks!! Tina |
Post Options Quote Reply Posted: 02 Aug 2014 at 8:08pm |
ditto
jan demarinis
Groupie Joined: 22 Apr 2014 Location: Northern CA Online Status: Offline Posts: 54 |
Post Options Quote Reply Posted: 02 Aug 2014 at 5:12pm |
I like it! Nice work. Have a great trip.
2014 178 HRE
The Podyssey 2013 BMW X3 35i Prodigy RF Brake Controller |
SuJoPodders
Newbie Joined: 02 Jun 2013 Location: Janesville Ca. Online Status: Offline Posts: 16 |
Post Options Quote Reply Posted: 02 Aug 2014 at 3:32pm |
Latest update on our 177 mods.
Leaving in a day for a month long trip to Alaska. Trying to make it as livable as possible. Curb side rear shelf. Street side rear shelf. Adapted shower caddy. Storage pockets moved from bathroom. Storage pocket from shower. 24" AC/DC TV/DVD View of TV from bed. Mount attached to kitchen slide out. Custom made Cribbage Table. Mounting hardware. |
GingerPod
Groupie Joined: 09 Jul 2014 Location: Pinehurst NC Online Status: Offline Posts: 67 |
Post Options Quote Reply Posted: 30 Jul 2014 at 10:50pm |
Thanks for the heads up on the converter charger. Yeah both batteries are hooked together for use. Together also for charging,by either Solar or Convertor and of course while driving down the road. Double the available amps,both are 12V,should keep good for days dry camping! |
FOUND OUR NEW-RETRO TEARDROP!!!
Post Options Quote Reply Posted: 30 Jul 2014 at 9:41pm |
No worries about the converter overcharging, it is a proper 3-stage charger. Also if those batteries are two 120 volt batts, you'll get more total amperage by always charging and using them together instead of one at a time. Look up Peukert Effect for techie info.
GingerPod
Post Options Quote Reply Posted: 29 Jul 2014 at 11:20pm |
I just finished adding a 2nd battery....
I used a Marine cutoff switch mounted directly to the Battery box. I can now isolate the battery from the camper at anytime.,But retained a permanent connection to the Zamp port so I can charge from the Solar panel at any time regardless of cutoff switch position. Also enables me to be plugged in to shore power any length of time without fear of over charging the batteries or boiling them to bits Plus I added a steel cable and lock to keep honest people honest.... |
