Tire wrench! |
Post Reply | Page 12> |
Leo B
Topic: Tire wrench! Posted: 15 Jun 2016 at 2:37pm |
100 lbs
Oliveman
Newbie Joined: 16 Mar 2016 Online Status: Offline Posts: 23 |
Posted: 15 Jun 2016 at 1:53pm |
How much torque do you set the wrench to when tightening the lugs?
2016 R-Pod 178
2015 Pathfinder Platinum AWD Wife, Child and Dog on adventures |
Leo B
Posted: 13 Jun 2016 at 3:21pm |
You can get a torque wrench that cover 100 lbs at Wal-Mart of 25-30 bucks also the socket etc can all be gotten there.
Jewel59
Groupie Joined: 19 May 2016 Online Status: Offline Posts: 70 |
Posted: 13 Jun 2016 at 3:10pm |
Sounds good, I've ordered a torque wrench and an appropriate wrench for the lug nuts.
Posted: 13 Jun 2016 at 11:36am |
Some people swear by using a lubricant on the lug threads. My local mechanic does it. I don't, I disagree with using it except in extreme cases, partly because it is hard not to get it on the angled mating surface between the bolt and wheel. Even with a careful wipe-off of those surfaces I feel like I'm over torquing. I have it on now because my mechanic added it when he put new tires on, it will be interesting to see how the nuts retain their torque on our upcoming long trip.
Jewel - check every 50 miles for the first 200, then before every trip. Eventually you'll find they have seated themselves and don't move when you check them and then you can check less frequently.
sailor323
Senior Member Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
Posted: 13 Jun 2016 at 8:08am |
Jewel59
Posted: 12 Jun 2016 at 8:53pm |
Oh Lordy, glad I asked. I have a 500 mile drive coming up this this Thursday. I do have a year of roadside but checking the toque of the wheel lug nuts is an immediate concern.
Posted: 12 Jun 2016 at 8:42pm |
Good idea Doug. I had that problem on an older Jayco (93) that had a flat when it was over 10 years old. Needed a cheater bar to break all the lugs loose. Learned my lesson after that one. Now I break the lugs and re-tighten once/year so that doesn't become an issue again.
Posted: 12 Jun 2016 at 8:36pm |
I would also get a breaker bar with cheater to use with the extension + socket to break the bolts free w/o damaging the mechanism in the torque wrench. Useful if it is seized and you need to put some weight or hammer into it.
Posted: 12 Jun 2016 at 8:32pm |
Just an FYI on those lug nuts. My 4-way wrench does not fit the smaller opening on the pod's wheels. To remedy that you will either have to grind down the proper end on your 4-way (the 3/4 inch socket) so it will fit inside the opening or get a deepwell, thinwall 3/4 socket to fit your 1/2" drive rachet. Mine is a 2011 so check the socket size on your unit. FR may have changed sizes of the lugs from 5 years ago.
