  New Posts New Posts RSS Feed: Best Method for Propane Level guesstimates?
Topic ClosedBest Method for Propane Level guesstimates?
 Post Reply Post Reply Page  <1234 5>
Tars Tarkas View Drop Down
Direct Link To This Post Topic: Best Method for Propane Level guesstimates?
    Posted: 31 Mar 2016 at 1:10am
What Marwayne said.
JohnBG View Drop Down
Direct Link To This Post Posted: 31 Mar 2016 at 10:39am
I have a tank gauge because I don't feel like unstrapping/unbolting the tank.  When we camp, we don't use the heat and electric for the water heater, so the only gas we use is for cooking.  I've camped 7 or 8 weekends and still have over half a tank left.
2010 R-Pod RP-171
2010 Honda Ridgeline TV
Direct Link To This Post Posted: 31 Mar 2016 at 9:47pm
Make that a 3rd.  I do as Marwayne and Tars Tarkas.  No worries, when one tank is empty, switch over to the other (hopefully filled) one.
Retroactive View Drop Down
Direct Link To This Post Posted: 01 Apr 2016 at 9:07am
I'll have to see how much propane the furnace uses in the early season. If all goes well we will be going to the beach every opposite weekend, starting on the 15th.  The cottage is near the beach inside a bay, the temps are as much as 10F higher than 50 miles inland this time of year. If the wind blows from the south it is warmer, if it shifts from the north it can still get chilly at night. If we use a lot, then double tank mod gets bumped up on the list to get done before fall.
CharlieM View Drop Down
Direct Link To This Post Posted: 01 Apr 2016 at 2:56pm
Starting from the first post there are two issues: propane measurement and propane management. For measurement, how much is in a tank, I really like the ultrasonic devices. Much easier than removing and weighing a tank. For propane management the dual tank with automatic change over can't be beat. If you watch the switch indicator and refill when it's red you'll never even need to know how much is in a tank, except for beginning a trip/season. But we incurable techies do both.
TheBum View Drop Down
Direct Link To This Post Posted: 01 Apr 2016 at 6:44pm
I'm considering getting a 30-lb tank to save on weight vs. two 20-pounders.
Patriot Dave View Drop Down
Direct Link To This Post Posted: 01 Apr 2016 at 7:49pm
Originally posted by marwayne
I have two tanks, when tank one is empty I hook up number two and keep my eyes open to refill number one
I like your method. Its full proof and a no brainer.
Dave & Joyce
Direct Link To This Post Posted: 01 Apr 2016 at 7:50pm
I use the shake method. Pick it up and shake it and from the slosh and weight I just how full it is.I also have a 20 pound tank on my Weber Q that can be used if I ever run out.
Direct Link To This Post Posted: 01 Apr 2016 at 9:15pm
I don't like to spend the time and hassle of removing my tanks so I prefer the hot water method.  Tells you exactly where the liquid line is.  Just remember that even when full it will only be 80% full, or just below the bottom of the top shoulder.
P and D Podders View Drop Down
Direct Link To This Post Posted: 08 May 2016 at 11:20pm
Just how does the warm water method work? I have just returned from a trip to Colorado and after using the heat for 4 nights and cooking we only used 2 gallons. A 20LB tank holds about 5.5 gallons.
