De winterizing |
Post Reply | Page 12> |
Idaklee
Groupie Joined: 18 Sep 2015 Location: Minnesota Online Status: Offline Posts: 46 |
Topic: De winterizing Posted: 28 Mar 2016 at 12:16pm |
Hi....soon I'll have to dewinterize...so am reading up on it and will have several questions. First one....what's with the "white" hose? What's special about it?
Thanks, Marcia |
Marcia from MN
13 177 R Pod 06 Dodge Grand Caravan Max, Gracie & Greta |
Guests
Guest Group |
Posted: 28 Mar 2016 at 5:39pm |
If you are speaking of the "white" hose that resembles a garden hose,
it is used to fill your fresh water tank or connect your Pod to a "city" water supply (if you do this, it is recommended to use a pressure regulator). The "white" hoses are made from materials believed to be safe for the delivery of potable water. Generic garden hoses CAN be from materials which might contaminate the water with "not so good stuff" (like lead). They are not intended to be a part of a potable water system so, they can be made of whatever the manufacturer wants. Maybe it's OK for human consumption, maybe not. |
Idaklee
Posted: 28 Mar 2016 at 7:53pm |
Ok, I got it! Thanks.....next question. When checking to be sure the switch is set the right way where the pink stuff goes in, how do I know which is the right way?! I had my RV service person winterize, so I've no clue. Thanks!
Marcia from MN
Posted: 28 Mar 2016 at 8:58pm |
The handle should be perpendicular to the short hose you stick in the antifreeze jug. Also make sure the valves behind the water heater are set right. In summer the middle one should be perpendicular to the line. The other two should be parallel to their lines.
Idaklee
Posted: 28 Mar 2016 at 9:45pm |
Great! Thanks!
One last question and this will sound unusual, to say the least...but....my water heater valves are in the cabinet under the bed and I'm not sure I can get to them by myself. So in case I can't get that part done prior to leaving....all that will mean is that I can't have any hot water, right?? I could still go and use water, toilet, etc...right? |
Marcia from MN
Posted: 28 Mar 2016 at 10:53pm |
Yes, you are correct. Everything will work fine except you won't have hot water.
Depending on your pod, the valves are easily accessible by opening the hatch above the water heater (it may be hinged and just lift up, or you may have to remove a few screws) or there is vertical panel on the inside of the pod right in front of the back side of the water heater that comes off by removing 4 screws. So worst case, you need to know how to work a screwdriver to get to the valves. TT |
FJ Cruiser |
Idaklee
Posted: 29 Mar 2016 at 11:24am |
I have a 177 and when the RV guy winterized it for me, one guy had to hold the bed up while the other guy got down on his knees, unscrewed a panel to reach the valves!
Marcia from MN
Posted: 29 Mar 2016 at 12:03pm |
You can cut that panel to make it much easier to deal with. |
Posted: 29 Mar 2016 at 12:04pm |
Depends on your layout... It might be that all you really need to do is lie down on the foor & do the screws. I should have said though, be absolutelty sure not to fire up the gas on the water heater or turn on the electric element until you have the WH filled with wateR.
TT |
FJ Cruiser |
ron_whitt
Senior Member Joined: 08 Sep 2011 Location: Chesterville On Online Status: Offline Posts: 261 |
Posted: 02 Apr 2016 at 9:17am |
Idaklee, we have a 177 also. Cut yourself a piece of wooden dowel 3/4" about 16in long and use that to hold up the plywood while you change the valves. Also for de-winterizing or winterizing I threw away the small screws that hold the panel on in front of the water pump. I placed Velcro on the sides of the panel, put 2 small pieces of cloth to be able to pull the panel off, and then colour matched small cork pieces (any $ store will have them)and glued them over the screw holes.. Good luck. and welcome.
Ron & Shirley
2020 Tacoma 2012 177 rpod |
