Using fan on battery power |
Post Reply | Page <123> |
Topic: Using fan on battery power Posted: 21 Mar 2016 at 12:23pm |
If your pod isn't plugged in at home, they are going to go dead in only a few to 10 days. The pod has several unavoidable parasitic draws. If you are not running the air conditioning, you can plug into a standard outlet in your garage etc, using an adapter.
Your van may, or may not be able to charge your batteries while towing. A full charge, on a set of dead, or mostly dead, GC-2s, by a tow vehicle, would probably take a 24 hour tow. If it can do it at all. Try to avoid depending on the tow vehicle for battery charging, unless you are towing somewhere every day, and have shore power at the CG. |
howmanyds
Groupie Joined: 07 Feb 2016 Location: Murrieta, CA Online Status: Offline Posts: 71 |
Posted: 21 Mar 2016 at 2:46pm |
Oh, ok. Thanks! I'll definitely charge it up all the way on packing up day.
I also put a switch on the batteries to shut them off when it's parked. To digress... I'm having a dilemma with that battery switch because it uses 4 gauge cable. I want to run my inverter with 0/1 gauge cable which means I can't run it through the switch. Am I right in thinking I would need a separate switch with 0/1 or just let the inverter be controlled by its own remote? Also, I just realized that the zamp cables should probably bypass the switch too so that when I get solar panels they can still charge up the battery even when it's switched off... Not sure when I'd be leaving out the panels when the battery is off but anyway... Sorry - thinking out loud. |
Posted: 21 Mar 2016 at 2:59pm |
What inverter did you buy? Those are awfully large cables.
Keith-N-Dar
Posted: 21 Mar 2016 at 7:20pm |
If it needs that large a cable you won't have to worry about using it for long on battery power...
Keith-N-Dar
Posted: 21 Mar 2016 at 9:11pm |
I agree about the built-in fan, it will produce a nice breeze through the open windows.
howmanyds
Posted: 22 Mar 2016 at 1:29am |
The inverter is just a modified sine 1500W energizer inverter: https://www.amazon.com/dp/B00APL77T6/ref=cm_sw_r_cp_awd_hpn8wbE1MF5V3
I don't plan to use it continuously, but if I need to, say, use my heat gun for a few seconds while its at the storage facility without power in order to remove a pesky microwave sticker, then I'll have that option. I'm also going to test the TV and see if it works with modified sine. The I'll have to do some trials and see how many (if any) movies we could watch on a three day trip without running the two batteries all the way down. Of course, we've never watched movies while camping before -- seems like that's not the point, really -- but I want to know my options. The reason for the size is that I'm installing the inverter nearly ten feet of cable away. With a peak of 3000W, and with 80% efficiency, we're looking at an amperage draw of 200A. From everything I read 2/0 would be a safe bet, but a little overkill in wire thickness never hurt anyone. Besides, I found a cheap and well-rated 0/1 cable from Amazon that is in a kit for powering amplifiers/subwoofers. The cable is quite flexible. |
Posted: 22 Mar 2016 at 9:02am |
You realize what will happen to your batteries if you draw at a 200aH rate for any kind of extended time, ie: longer than 4-5 seconds? Lead acid batteries just don't like that. And the faster they are discharged, the shorter, much shorter their life and charge.
CharlieM
Posted: 22 Mar 2016 at 9:33am |
You've got to be kidding! 1500W from a 12V system? I'll take the contract for replacement batteries.
howmanyds
Posted: 22 Mar 2016 at 11:18am |
Oh! 😳
I think I got bad advice last summer when I picked this thing up for my van. Ended up not installing it. Clearly, didn't do enough research. What would be an acceptable amount of power in an inverter? |
TheBum
Posted: 22 Mar 2016 at 3:30pm |
An inverter needs to be sized according to peak surge power, not just continuous power. I would agree that 1500W is excessive though. I'm installing a 400W inverter, which will have plenty of overhead for anything I'm likely to plug into it. Mostly, it will run the TV when I'm off the grid; the TV is only rated at 17W.
