  New Posts New Posts RSS Feed: Combining Black & Gray dump lines
Topic ClosedCombining Black & Gray dump lines - Event Date: 07 Mar 2016
Direct Link To This Post Calendar Event: Combining Black & Gray dump lines
    Posted: 08 Mar 2016 at 2:00pm
Remember that you can leave the gray water valve open when you have a sewer hookup, but you need to leave the black valve closed until the tank is at least 2/3 full (before dumping close the gray valve to collect a shower or two worth of water to help flush the line). So leaving them separate isn't as big a problem as you might think, as Capt discovered.
Capt Kidd View Drop Down
Direct Link To This Post Posted: 08 Mar 2016 at 12:01pm
One easy way to do this is to use a 5 foot hose on each outlet and then connect them to a Y and then run that single to the dump. All the parts are readily available at any RV outlet.
I did this and then found that it was just easier to dump each one when I needed to.
Yessaco View Drop Down
Direct Link To This Post Posted: 07 Mar 2016 at 3:31pm
I would like to combine my grey water and black water outlets on my 179 with risers. I have seen a post here a while back that gave specific instructions as to how to do it and what parts to order. Can someone please repost that. I think I have most of the parts but would like the instructions so I don't make a major mistake cutting something wrong. Thanks.
179
Chevy Tahoe
Jan & Bob
