Reverse lights. |
Post Reply | Page <123 |
Topic: Reverse lights. Posted: 16 Feb 2016 at 9:29pm |
Interesting, hadn't seen that controller before.
Posted: 16 Feb 2016 at 8:20pm |
I have been very happy with the Hopkins InSIGHT Flex-Mount controller:
https://www.etrailer.com/Brake-Controller/Hopkins/HM47297.html I like having the display on top of the dash where I can see it and the control where I can easily reach it. The Smart Box is the only part that has to be in a certain position so the inertial sensors work properly. The other two parts can mount in any location that works for the person who will use it. It is also significantly lower in price than the Tekonsha P3. Installation was not too hard. I did not have the connections in my 2016 Escape (with factory tow package pre-wired with a 4 pin connector), so I had to run wiring from back to front for the electronic brake controller and 12V for battery charging. I had to use the universal ETBC7 kit to install this. If your TV has the connectors built-in, you may be able to use a vehicle specific wiring kit, which would certainly be simpler. You would have the same issue even if you did go with the P3 controller. |
howmanyds
Groupie Joined: 07 Feb 2016 Location: Murrieta, CA Online Status: Offline Posts: 71 |
Posted: 16 Feb 2016 at 7:33pm |
Yes, I'm most likely getting a Tekonsha P3 electronic brake controller. I found some wiring instructions at etrailer.com.
Posted: 16 Feb 2016 at 7:16pm |
As part of that modification, you are installing a brake controller, right? |
marwayne
Posted: 16 Feb 2016 at 7:01pm |
The pod is wired for backup lights, all you have to do is put in backup lights and hook them up.
Posted: 16 Feb 2016 at 6:20pm |
7 pin wiring is standard thru out the industry.. if there are back up lights, there is no other configuration.
howmanyds
Posted: 16 Feb 2016 at 5:52pm |
Thanks. So, are R-pods configured to use that 7th pin with some other auxiliary function?
CharlieM
Posted: 16 Feb 2016 at 5:48pm |
No reverse lights. Only running, brake, and turn.
howmanyds
Posted: 16 Feb 2016 at 4:57pm |
I'm planning to mod my 4-pin trailer connection into a 7-pin connection before going to pick up my R-pod from the dealer. Are there reverse lights on rpods?
Thanks! |
