  New Posts New Posts RSS Feed: Charging Accessorys
Topic ClosedCharging Accessorys
CharlieM View Drop Down
Direct Link To This Post Topic: Charging Accessorys
    Posted: 21 Feb 2016 at 8:11am
The best way to charge cell phones, laptops, and similar 12V devices is directly from 12V outlets without an inverter. The 12V current draw is less without the inverter. An inverter changes 12V DC to 120V AC. Then the cell phone charger must convert 120V AC back to low voltage DC. Each conversion wastes energy, giving off heat, thus increasing total demand on the battery.
Patriot Dave View Drop Down
Direct Link To This Post Posted: 21 Feb 2016 at 6:33am
I am a Newbie and hope to pick up our new Rpod in the next week or so.
Reading your reply here regarding an inverter.
So with the inverter I can charge things like cell phones, lap tops and so on........my question is when charging theses devices is the draw on the batteries more or less than adding a few 12 volt outlets?
Thanks
Patriot Dave
Dave & Joyce
Don Halas View Drop Down
Direct Link To This Post Posted: 20 Jan 2016 at 12:43pm
I installed this in our 178.   2 usb ports and one 12v socket.
http://www.amazon.com/gp/product/B00N3I1NZW?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
Direct Link To This Post Posted: 19 Jan 2016 at 5:35pm
Got down to 9 here last night.  Love the cold.  When it is inside the ice cubes in my drink.
Only owned 1 pod, a 2010 171 which we sold almost exactly a year ago.
Direct Link To This Post Posted: 19 Jan 2016 at 12:27pm
Thanks, I will do that as soon as I finish here.  It is a balmy 20 outside right now, quite a warm-up from the past few days.  Guess I will give them a 2amp trickle charge as well to get them through until spring.  BTW  is your 171 the 2nd pod you've owned?  Didn't you have a 2009 before?
Direct Link To This Post Posted: 19 Jan 2016 at 12:18pm
Jato, keep your batteries outside where the cold will preserve their life, and reduce their internal discharge rate. If you keep them inside you still should be charging them monthly, if they are outside and it is cold out you can go with one charge in the middle of winter.
50% SOC normally, only occasionally go to 30% SOC to preserve the life.
Direct Link To This Post Posted: 18 Jan 2016 at 2:15pm
Originally posted by furpod
.. but even from one end of the trailer to the other, it's all short runs, and the voltage drops are pretty minimal, as long as the gauge of the wire is correct.
One advantage of wiring directly to the converter panel: Regardless of the length the meter will be essentially correct if there is nothing running from the outlet itself. Connect with #12AWG and you're good to go.
Direct Link To This Post Posted: 18 Jan 2016 at 12:16pm
Thanks, looks good.  Nice job.
Direct Link To This Post Posted: 18 Jan 2016 at 11:55am
Originally posted by jato
Thanks Mark !  What made you decide to trade out your 12v/marine (same as what I currently have) for the Trojan T-105s since they still tested 100% life?  And, what did the Trojan batteries set you back?  I like the 110 hours that the 2 6v batteries give.   With the 12v we usually go 4 days on one before switching over to the other and that is in colder weather when evening temps run 30 - 45 degrees.  However I am drawing it down to about 33% SOC.
A) They were 5 years old, and I would rather trade them then have them fail when I needed them. And we wanted the capability to be off grid longer. we also like to late and early season camp where temps can be well below freezing, heater runs a lot more then.
B) Box and batteries, it was about $400 total.
If you click my mod link and go to page 9, whole setup is there..
Direct Link To This Post Posted: 18 Jan 2016 at 11:50am
