  New Posts New Posts RSS Feed: new table in 178
Topic Closednew table in 178 - Event Date: 14 Nov 2015
Direct Link To This Post Calendar Event: new table in 178
    Posted: 18 Nov 2015 at 6:25pm
Commander, I'm much like you but believe it or not I'm planning on making custom kitchen and bathroom cabinets in the nearer future with my father-in-law.  Not the fronts or drawer boxes (for the nice dovetail look), those I will order custom and unfinished.  All of the enclosed surfaces will be furniture grade plywood and then if we don't paint, solid wood for the exposed ends.  I figure even with buying some tools I need like a decent table saw, I'll still save about $20k over the quotes we received last year.  Plus then I can fit everything perfectly around the appliances.
Commander203 View Drop Down
Direct Link To This Post Posted: 18 Nov 2015 at 9:22am
Very nice table. I have zero talent when it comes to working with wood. I can't even saw a straight line.lol
Mike & Erin
2013 Tundra 4.6L V8 (Tow PK)
2006 Honda Goldwing GL 1800
2005 Honda VTX 1800N
Pod People View Drop Down
Direct Link To This Post Posted: 18 Nov 2015 at 9:13am
yes, we made all of the table hardware.  the aluminum braces are 1/4" flat stock with small lag bolts attached to the legs.  I used star knobs and steel tee nuts (1/4x20) from Woodworkers Supply (woodworker.com) for the connectors.  Standard piano hinges were cut to length for the leg to table top hinge connection. Hope this helps you-let me know if you need more details.
I started with a mock-up and the table top was larger.  We keep cutting it down in size until we thought it was as large as possible while still being usable and would fit as we wanted it.  then we made the real unit
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 17 Nov 2015 at 9:38am
Did you make the hardware (the removable supports)?
Direct Link To This Post Posted: 16 Nov 2015 at 10:04pm
We also built a new table for our 173.  We don't use the dinette area for sleeping, so the table didn't have to be the same size in order to fit between the benches and make the bed platform.  It is made from 3/4" cabinet grade(10 ply) birch plywood.  the finish is 10 coats of table varnish.  It folds flat for traveling and is very sturdy.
travel safe
Vann
s&lmaz View Drop Down
Direct Link To This Post Posted: 16 Nov 2015 at 2:16pm
 Thanks .  Just remembering NOT to lean will be the catch.Smile
Direct Link To This Post Posted: 16 Nov 2015 at 2:13pm
   Your table looks great.  Looks much more convientant in small space.Thanks for sending the picture!
Direct Link To This Post Posted: 16 Nov 2015 at 2:05pm
    Thank you for the suggestions!
Direct Link To This Post Posted: 15 Nov 2015 at 5:44pm
It is the anti-gravity option!
john in idaho View Drop Down
Direct Link To This Post Posted: 15 Nov 2015 at 4:00pm
I replaced the table in my 179 with a similar table.  I screwed the base into a piece of 3/4 plywood the same size as the top.  That way we can scoot the table around or even take it apart for travel by laying it on the bed.  I made the top rectangular so we can use different seating positions, or slide it out of the way.  Much handier than a fixed table.  One just has to learn not to lean on the table when getting up.
