light weight generator? |
cgarb
Groupie Joined: 27 Mar 2011 Location: California Online Status: Offline Posts: 95 |
Topic: light weight generator? Posted: 21 Oct 2015 at 10:46am |
We generally dry camp and like to be out in the wilderness without hook ups. We are also getting a bit long in the tooth with bad backs, knees, shoulders.... Does anyone have a recommendation for a light weight generator that can be used to charge the batteries (we have 2 on our 177) when we are on a long trip? We also camp in the shade and along the foggy coast as much as possible, so aren't sure how solar would work for us. Thanks for any suggestions!
Carol
177 HRE rpod 2014 Honda Pilot |
Guests
Guest Group |
Posted: 21 Oct 2015 at 11:44am |
I have the Champion 2000 watt inverter generator which I purchased at Camping World (on sale) for $499. It's specifications are similar to the Honda but, quite a bit less money. It will run everything except the air conditioner. If memory serves, it weighs about 50lbs. I have been pleased with it.
Outbound
Posted: 21 Oct 2015 at 12:11pm |
If charging your batteries is your only requirement, and if the budget allows, a Honda EU1000i would be my recommendation. Extremely quiet and extraordinarily reliable. And it'll weigh just over 30 pounds with gas in it.
If the budget isn't there, then - if you can find one - the Hyundai HY1000si would be my recommendation. I had one of these for years when we had a tent trailer and was very happy with it; my ex and I did a great deal of dry camping and used it almost exclusively to recharge the battery. It was quiet, light (around 30 pounds), and fairly compact and very reliable. Just remember to change the oil (put in synthetic after its broken-in) and the sparkplug at the beginning of every spring and it'll purr contentedly all camping season.
But, remember, neither of these would power the air conditioner or oven/microwave. |
Posted: 21 Oct 2015 at 1:48pm |
+1 to the recommendations above.
SNO4ME
Senior Member Joined: 28 Sep 2013 Location: NW Wis Online Status: Offline Posts: 122 |
Posted: 23 Oct 2015 at 11:59pm |
Early this Fall we bought a Champion 2000 too. Now I'm spoiled by the "everything but the air". Maybe someday we will get another to run the air conditioner but how many places can you run a generator all night anyway. |
Bruce & Donna in the Sno Pod
(and Brewer too) 2011 RP 177 |
ToolmanJohn
Posted: 24 Oct 2015 at 9:06am |
I also recommend the Honda EU1000i. If all you want is charging the batteries in remote locations, it's light and reliable. All you would get out of a 2000 watt generator is the Microwave and possibly the A/C (if you shut all the other breakers off).
johnmaci
Senior Member Joined: 17 Jun 2014 Location: MD Online Status: Offline Posts: 202 |
Posted: 24 Oct 2015 at 9:35am |
I have the Ryobi RYI 2200 Inverter bought at Home Depot for $549. You can run some minor appliances and charge the batteries too.
https://www.youtube.com/watch?v=qZFCh27h4Tg I might also recommend the the Yamaha EF1000is if solely charging batteries and the budget is right: https://www.youtube.com/watch?v=g3ff7ez5kP0 So far so good with the Ryobi, not too noisy or heavy |
jstrenn
Groupie Joined: 14 May 2015 Online Status: Offline Posts: 71 |
Posted: 24 Oct 2015 at 12:19pm |
If all you need is to charge the batteries, why don't you just hook up jumper cables to your tow vehicle. Let the tow vehicle idle for an hour or so and your batteries are charged. Cost is way less than buying a generator. You can buy a really good set of jumper cables for $40 or $50. A lot lighter too!
Posted: 24 Oct 2015 at 2:45pm |
SNO4ME - in our case we stay at truck stops, Wal-Marts, etc. multiple times a year and we will run the genset all night there.
jstrenn - that is a good option for a trip or two a year, not sure I would want to do that all the time.
podderfj
Groupie Joined: 13 Oct 2015 Online Status: Offline Posts: 57 |
Posted: 24 Oct 2015 at 6:46pm |
My EUHonda 2000 generator/inverter runs my ac just fine in my 172 pod. It will run the ac, all of the lights, the bathroom fan, all at the same time. However, when you run the microwave, you have to turn the ac off, or if you run anything with a heavy electrical draw, you have to turn the ac off. I have read on several posts on here that the Honda 2000 will not run the ac, but it will run my ac with all of the other items that I listed above. I think is weighs 47 pounds.
