  New Posts New Posts RSS Feed: window screen
Topic Closedwindow screen
john in idaho View Drop Down
Direct Link To This Post Topic: window screen
    Posted: 18 Oct 2015 at 6:09pm
Will give it a try.  It didn't look like there was enough clearance.
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 17 Oct 2015 at 8:41pm
There is a special tool for pressing the screen in the channel.  It looks like a small plastic pizza cutter wheel.  Actually, it is commonly a double-ended tool.  One end to push the screen in the channel and the other to press in the gasket.  The screen end has a wheel with a rounded edge and the gasket tool has a concave edge.  It's very simple to do, and the tools are cheap, probably under well under $10.  Get the cheapest one available unless you're thinking of going into the screen repair business.
Search for "screen tool" on Amazon.  $4.90.
ronahue View Drop Down
Direct Link To This Post Posted: 17 Oct 2015 at 5:03pm
I had a similar situation on my 179 and repaired it in place using the screw driver of a small swiss army knife to push the rubber gasket into the grove after stretching the screen. I no I am not explaining this well but the screen is the same as a house screen so if you have ever repaired one you may understand what I'm explaining so poorly.
I hope this helps
Ronahue
Ron & Sharon
2015 R-Pod 179
2022 Nissan Frontier
Direct Link To This Post Posted: 17 Oct 2015 at 4:15pm
Do you have to take out the screws that hold the entire frame on the inside?  Does it just pull out, or is there caulking etc on the inside?
Direct Link To This Post Posted: 15 Oct 2015 at 10:19am
Our little dog partially pushed out the window screen - above the bed in HRE 179.  I can't figure out how do take the screen and frame out to repair it.  Any hints?
