Hitch advice pls |
Post Reply | Page 12> |
Idaklee
Groupie Joined: 18 Sep 2015 Location: Minnesota Online Status: Offline Posts: 46 |
Topic: Hitch advice pls Posted: 13 Oct 2015 at 11:41pm |
Thank you! I M so glad I found this forum!
Marcia from MN
13 177 R Pod 06 Dodge Grand Caravan Max, Gracie & Greta |
Posted: 13 Oct 2015 at 9:09pm |
moved to the podmods section
Posted: 13 Oct 2015 at 9:03pm |
Slightly nose-down is fine and can help prevent sway. If you will stop somewhere w/o unhitching, like Wal-Mart, use the tongue jack to level it up - but put a big sign on the front seat reminding you to put it up before you get on the road.
Suggestion for the electric operation for the WH, leave that black switch on the outside "on" and use the circuit breaker on the converter to turn it on or off.
johnmaci
Senior Member Joined: 17 Jun 2014 Location: MD Online Status: Offline Posts: 202 |
Posted: 13 Oct 2015 at 2:03pm |
Water in the heater will always be OK, it's the pipes that run outside that cause problems.....
Idaklee
Posted: 13 Oct 2015 at 1:21pm |
Wow! I would never have known that..thanks! I'm going camping, leaving tomorrow, and it is going to hit 28 degrees. So I thought I'd heat up a bit, I. Hopes we will be okay. Getting winterized next Monday.
Marcia from MN
Posted: 13 Oct 2015 at 12:18pm |
Water heater runs on either, or both, your choice based on availability and needs.. The switch for the electric side is inside the outside WH compartment, lower left, slightly hidden. Small black togle switch.. marked on/off.. The switch inside the Pod is for the gas side.
Idaklee
Posted: 13 Oct 2015 at 11:35am |
I will thanks!
Another question...newbie, remember....does the water heater only run if the propane is on? Or does it also work on electric? I'm guessing it's propane only.... |
Marcia from MN
johnmaci
Posted: 13 Oct 2015 at 10:48am |
It should be as close to level as possible.
Watch this video for some good tips: https://www.youtube.com/watch?v=vYuQeWO0-FA |
Idaklee
Posted: 13 Oct 2015 at 10:28am |
The pod tilts forward and it's because my current hitch is low. Is it best to have it level while traveling?
I had an Aliner. With those, it's best to have it tilt back just a fraction to prevent water from running in if it rains hard while driving. |
Marcia from MN
Posted: 13 Oct 2015 at 9:17am |
Does the pod sit level because of your current hitch, or because the back of your tow vehicle is squatting? Two different issues.
