Dometic AC E4 Error 2015 RPod |
kymooses
Topic: Dometic AC E4 Error 2015 RPod Posted: 08 Oct 2015 at 9:17am |
Yes, very sorry to have not clearly stated it that way. That was what was rattling around in my head.
Posted: 06 Oct 2015 at 2:30pm |
Glad to hear you fixed it. The thermostat runs from the 12 volt system so the only way to remove all of the 12 volt power sources is to unplug the pod and disconnect the battery. That is what kymooses meant by "complete shutdown of power".
Irish Tom
Newbie Joined: 27 Jul 2015 Online Status: Offline Posts: 24 |
Posted: 06 Oct 2015 at 1:31pm |
Unplugged the RPod and it did not help.
Had to disconnect the battery and unplug and it cleared the E4 error message. Thanks, Irish Tom
kymooses
Posted: 05 Oct 2015 at 10:12am |
Sometimes it really is just a glitch of the t-stat. A complete shutdown of power to the entire camper and then plugging back in will sometimes just clear the error code.
This is the error code message for E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat Pump operation will be locked out. Air Conditioner, Fan and Furnace operation can continue to operate. |
Irish Tom
Posted: 04 Oct 2015 at 5:04pm |
Turned on my AC and am getting the E4 Error Message on my thermostat.
I have a 2015 RPod 178 and a 3 button thermostat. Is this a warranty issue or can it be cleared. Thanks, Irish Tom 2015 RPod 178
