Dometic refrigerator not lighting |
Leo B
Topic: Dometic refrigerator not lighting Posted: 05 Sep 2015 at 12:39pm |
Good tip!!
DebbieHM
Newbie Joined: 31 May 2015 Location: La Crosse, WI Online Status: Offline Posts: 18 |
Posted: 05 Sep 2015 at 11:00am |
Ours wouldn't work either after replacing the propane tank. Stove lit, fridge didn't. Our tech ( FMB Trailer Sales in Holmen WI) gave me this advice and it worked! Move the indicator light to propane. Do it three times. Then click the triangle flashing at you and do it again. It took me about 3 or 4 cycles of this and it finally lit. I hope your cure is as simple as this was!
I am currently unsupervised....the possibilities are endless!
Posted: 03 Sep 2015 at 5:06pm |
However.. It has a 2 year warranty, AND the warranty starts from time of sale, not from when the pod was built.
Also the yellow data sticker on the left front will tell you what model year your trailer is, as should your insurance card and your registration. |
Posted: 03 Sep 2015 at 3:10pm |
If you don't hear any clicking at all, the problem is in the igniter system.
The service shop may be partially right. The model that was in my 2010 (don't know if it is the same model in the newer pods) is made in Europe, unlike many other models. So, any part must be imported and is expensive. The gas valve was bad on mine. $69 part for most models, but for mine it was $400 - which I verified myself online. |
Happy Tripping
Posted: 03 Sep 2015 at 2:30pm |
I have a 171 purchased around March 2014, not sure if it's a 2013 model. On propane, stove lights but refrigerator doesn't, no clicking sound. Internet says clogging MAY be the problem, repair place says he can't repair because he can't get spare parts because Dometic doesn't make the refrig and parts are not available.
?? COMMENTS ?? (I'm off to Idaho on a major trip in 2 1/2 weeks and am getting my beloved R-Pod out of that guy's clutches ASAP but I need the refrig to work, I'll TRY to clear the clog, but if not I'll have to take it to another repair place in area.) |
