Clean up isle two! - Event Date: 10 Aug 2015 |
Pilot
Groupie Joined: 26 Jul 2015 Location: Pinckney, Mi Online Status: Offline Posts: 91 |
Calendar Event: Clean up isle two! Posted: 10 Aug 2015 at 10:49am |
Had a little problem with the flex drain line from kitchen sink coming loose from drain pipe to the gray water tank this weekend.
It happened when I closed the bumpout. The hose was to short and it pulled right off pipe. I had to pull a couple panels to get into trouble shooting. Forest River, don't you think you could clean up after yourselves? Just because it's in a hidden area doesn't cut it. It's a sign of professionalism. There were screws, wiring debris, cutout hole pieces,and a lot of sawdust. It would take less than 5 minutes to clean these areas before installing the last panels. |
hammockmadness
Groupie Joined: 07 Jul 2015 Location: Middleburg, FL Online Status: Offline Posts: 61 |
Posted: 10 Aug 2015 at 2:06pm |
Kind of tee's me off too. It would just add a little more quality and workmanship.
Dana & Regina
Fleetwood & Jasper 2014 181-G 2014 Silverado 4X4 |
Posted: 10 Aug 2015 at 3:25pm |
Unfortunately that is "normal" for the pods post-delivery.
Pilot
Posted: 10 Aug 2015 at 8:59pm |
I will say that RV Nation is working with me.
