  New Posts New Posts RSS Feed: Water pump problem
Topic ClosedWater pump problem - Event Date: 17 Jul 2015
kellyandkelly View Drop Down
Direct Link To This Post Calendar Event: Water pump problem
    Posted: 17 Jul 2015 at 10:52pm
I'm having trouble with my water pump in the 178. This is our first time primitive camping. Our water tank is full, and I turned the pump on. However, when the water comes out it sputters really bad and does not come out flowing correctly. I have checked to see if the lines have the air out but it doesn't stop sputtering. What am I doing wrong?
SNO4ME View Drop Down
Direct Link To This Post Posted: 17 Jul 2015 at 11:58pm
Sometimes ours sputters for quite a bit before all the air gets out.
Are you bleeding both the hot and cold faucets?
Bruce & Donna in the Sno Pod
(and Brewer too)
2011 RP 177
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 18 Jul 2015 at 6:37am
Make sure the valve that for adding antifreeze is closed.  That is how the system acts if it is open.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 18 Jul 2015 at 8:13am
This is the first, and most probable thing to check. It's also possible, though doubtful, that the water heater is purging.. But if you have used it for hot water before, and not drained it..
Direct Link To This Post Posted: 18 Jul 2015 at 10:09am
Where is that valve located so I can check to see if it's open?
CharlieM View Drop Down
Direct Link To This Post Posted: 18 Jul 2015 at 10:57am
It will be very close to your water pump and will be connected to the input (suction) side of the pump. It will probably have a short piece of hose connected to it that doesn't connect to anything.
Direct Link To This Post Posted: 18 Jul 2015 at 12:54pm
To add to Charlie's...on my 178 it's just behind the panel below the sink cabinet - four screws.
