CFWARREN
Topic: LED LIGHTS Posted: 29 Sep 2015 at 11:08am |
If you do a search on Amazon, you can find dimmable LED lights. You have to replace the entire unit, not just the bulbs....here's one:
http://www.amazon.com/dp/B007SYVREY/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=35EAROCS89OQL&coliid=I1F8ISEKIK510C
2016 179 - Hood River Edition
2008 Nissan Xterra
johnmaci
Posted: 28 Sep 2015 at 10:58am |
I use these since they are heat resistant (low heat), and work well with my LED lights.
We use the red for the main lights when we are out on Astronomical Star Parties, and the frost for the other lights. There are many other online vendors and many other combinations of colors. Much cheaper fix than replacing bulbs or fixtures.
http://www.stagelightingstore.com/Stage-Lighting-Store/Theatrical-Gel-Sheets-Clear-Diffusion
Podster
Posted: 28 Sep 2015 at 5:45am |
Someone suggested sand blasting the inside of the lens to hays it out, I thought that was interesting and I might try that at some point.
Cliff & Raelynn
Ranger 4.0/178
shimonunit
Posted: 28 Sep 2015 at 1:24am |
There must be some way to diffuse (soften) the light. What is the spacing like between the cover and the led array? Anyone?
Posted: 03 Jul 2015 at 3:42pm |
Just squeeze slightly and move away from the switch end.
Plantguy
Posted: 03 Jul 2015 at 10:22am |
Ii have trouble with that also. I'm afraid to break the cover...
Life is too important to be taken seriously!i
Plantguy
Posted: 03 Jul 2015 at 10:21am |
john in idaho
Posted: 03 Jul 2015 at 10:07am |
How does one get the cover off?
Posted: 03 Jul 2015 at 9:15am |
The gel sheets just dim them, and aren't permanent. Some owners have frosted the inside with paint.
Plantguy
Posted: 03 Jul 2015 at 1:00am |
Good idea but I wat to be able to use them , like to read...
