Page 12> |
sdc143 ![]() Newbie ![]() ![]() Joined: 18 Jul 2013 Location: Colorado Spring Online Status: Offline Posts: 14 |
![]() Posted: 29 Jun 2015 at 2:05pm |
Good day. Wondering if anyone has done the mod to overflow the grey tank (when almost full) into the black - seems we always have room in the black to spare. Worried about the "smell" releasing from the black tank (not the liquid in there - never more than 1/3 full with 4 people), so wondered if there is some kind of negative pressure (probably not the right term) for one way flow from grey to black when the grey hits a certain "almost full" mark. Tried searching, but no luck. Thanks for any suggestions!
R-Podimus Adventures Abound!
'14 182G HRE '14 Toyota Sequoia 2 little boys and 2 yr old mutt |
The easy solution is to keep the cap on and open both ports until they even out. Not perfect since it will probably drip and a lot of water will be left behind the cap when you take it off. Probably the cheapest of the better solutions is to drain gray water into a bucket and ferry it into the toilet. Repeat a few times.
CFWARREN ![]() Senior Member ![]() ![]() Joined: 12 Apr 2015 Location: Spokane, Wa Online Status: Offline Posts: 148 |
Oh I can't believe it, I just did that this last week, I thought I was the only one....!
The grey tank fills up much faster than the black, wish there was a better way to even them out. |
2016 179 - Hood River Edition
2008 Nissan Xterra |
Nope you aren't the only one! I investigated various methods last year because I was going to be on the road 3 nights in a row, and normally would fill up the gray tank after 2 nights with showers. Since I could take more fresh water with me I wanted to use some of that black tank space. Ended up using a campground on the 3rd night so I didn't need to do it but the bucket-to-toilet method probably would have been my choice.
Markie ![]() Groupie ![]() ![]() Joined: 22 Sep 2013 Location: Chambersburg PA Online Status: Offline Posts: 67 |
It sounds like it's time for one of the R-pod enthusiasts on this forum to incorporate a 12v marine transfer pump between the gray and black tanks to do the dirty work.
Mark & Vicki
R-POD 178 & 2015 Silverado 5.3L Weimeraner "Zeke" |
This topic has made a question pop into my mind.
My Rpod is the first RV I've owned that had grey and black water tanks, my prior RV experience was a Coleman Tent-trailer, which only had a fresh water tank. So my question is, why do RV's have separate grey and black water tanks? When I go to dump them, they drain into the same disposal outlet, there aren't separate outlets for grey and black water, in fact it's a bit of a hassle to switch the hose form black to grey, I get that it's nice to use the grey water to "clean out" your hose after flushing the the black tank, but what would be the harm in them running together into one tank....? |
JohnBG ![]() Senior Member ![]() Joined: 14 Apr 2015 Location: Deltona, FL Online Status: Offline Posts: 190 |
why not just use a bucket to drain a few gallons out of the gray tank and dump it down the toilet into the black tank?
2010 R-Pod RP-171
2010 Honda Ridgeline TV |
Outbound ![]() podders Helping podders - pHp ![]() ![]() Joined: 19 Nov 2009 Location: Oshawa, Ontario Online Status: Offline Posts: 767 |
I've used my FlowJet Mascerator Pump (aka "the poop cannon") to transfer grey water to the black tank via a hose into the toilet. But, as the need to do this only arises 1-2 times per year, I haven't rigged up anything more sophisticated.
I suppose you could connect the two tanks, but there are advantages to keeping them separate.
Ok, so elaborate, what are the advantages to having separate tanks?
Page 12> |
