  New Posts New Posts RSS Feed: Battery Issues
Topic ClosedBattery Issues
 Post Reply Post Reply Page  <1 234
Direct Link To This Post Topic: Battery Issues
    Posted: 22 Jun 2015 at 8:25pm
The question that needs to be asked in this discussion. What came first; the chicken or the egg?
OnTheRoad6 View Drop Down
Direct Link To This Post Posted: 14 Mar 2016 at 8:20am
Someone please help this ignorant (!) trailer newbie!
I guess, based on what I am reading, that I should disconnect the battery on my Pod as it is stored where I don't have electricity. But I've also read several opinions for disconnect -- is it negative first, positive second, or positive first, negative second, or just positive or just negative? Smile
I won't do the switch option now after spending a ton of money to get the breaking system installed. I can't do it myself so have to pay big bucks for everything -- this RV thing gets expensive! It's okay and totally worth itSmile
Thanks for any help you can give me.
Direct Link To This Post Posted: 14 Mar 2016 at 8:53am
You only need to disconnect one lead. Disconnect which ever one you want. It's a Ford-Chevy, Blondes-Brunettes argument about which is better. I do the positive.
CharlieM View Drop Down
Direct Link To This Post Posted: 14 Mar 2016 at 8:56am
If you store without electricity you should disconnect the battery. It's only necessary to disconnect one side. Simply removing the lead with a wrench works just fine and the price is right. IF you ever might plug in the Pod before reconnecting the battery a weak argument can be made to disconnect the negative side, otherwise disconnecting the positive is customary. That said, it really makes little difference.
Direct Link To This Post Posted: 14 Mar 2016 at 10:01pm
Unless you disconnect the battery while the pod is plugged in, then the loose positive connection could short to the frame.  My personal reason for going with positive.
Direct Link To This Post Posted: 14 Mar 2016 at 10:07pm
However, if a loose negative contacted the frame, there would be no issues whatsoever. That is another reason for going with negative.
Direct Link To This Post Posted: 14 Mar 2016 at 10:31pm
Doug, I'm missing your point here. The possibility of the positive lead contacting the frame when the Pod is plugged in was my weak concession to disconnecting the negative. Otherwise I agree positive is per convention.
