wire harness - my dumb mistake, any suggestions? |
Post Reply | Page <12 |
MontyD
Newbie Joined: 16 May 2015 Location: Canyon Lake, TX Online Status: Offline Posts: 18 |
Topic: wire harness - my dumb mistake, any suggestions? Posted: 21 May 2015 at 9:59pm |
6 ... black, brown, blue, white, green, yellow. I connected them according to my dealer's order (and the diagram I posted above) and the only light that worked was the right tail light when I turned on my headlights. So it seems to me that maybe either I don't have a good connection on some of the terminals I connected or they are not in the correct order or maybe I should be checking some fuses somewhere. I have most of my tools & test equipment packed away because I'm preparing to sell my house & move. |
Posted: 22 May 2015 at 2:03pm |
Just flash your headlights when you are going to make a right turn.
6 wires takes care of the main functions. Usually blue is brake controller output, yellow/green/brown are for left brake/turn, right brake/turn, and running lights (not sure which), white and black for power and ground (not sure which). I would narrow down the failure points by leaving the pod out of the equation for now. Use a voltmeter or light bulb on the connection on the TV to figure out which pin is for brake light, right turn, left turn, etc. Use a known good ground on the TV and not the wire you think is ground.
