  New Posts New Posts RSS Feed: Water Heater
Topic ClosedWater Heater
Direct Link To This Post Topic: Water Heater
    Posted: 04 Apr 2015 at 10:51am
We bought a threaded plastic cap at the hardware store that screws into the anode hole. We still use the plumbers tape on it to keep it closed for the winter.
ron_whitt View Drop Down
Direct Link To This Post Posted: 04 Apr 2015 at 10:39am
While winterizing, after taking out the plug, like you did Bll stick the water hose in the anode hole a few times to "flush" out the hot water tank. You will notice a lot of white chunk come out. I use a mixture of baking soda and water with a toothbrush to clean out the threads of the tank. I do this both winter and spring. I leave my anode rod out over winter BUT place a large plastic bag behind the compartment door as the last thing to do for the hot water tank. So far (fingers crossed) no unwanted guests come spring time sanitizing.
Ron & Shirley
2020 Tacoma
2012 177 rpod
BillR View Drop Down
Direct Link To This Post Posted: 04 Apr 2015 at 10:12am
My 2-cents worth: I brought my (used) 177 home from the dealer last fall. When weather got colder, I dutifully studied up and winterized the unit. I drained the hot water heater, which I had noticed had the anode removed when I viewed the unit at the dealer. So I drained it, and aimed the hose inside. What an unpleasant surprise! I couldn't believe the slime and bugs and scale etc. that came out of there! It was really gross!! At the least, it was disgusting, at worst I could see it plugging pumps and faucets. The suggestion to put a plug in to prevent critters etc. is a good one, for sure. I will sanitize quite thoroughly this spring.
My unit had been mothballed at the dealer for most of the summer, having been traded in after very little use. They must have left the anode out all the previous winter and into August, when I purchased. So, even if you don't have a rigorous winter, I would recommend flushing the water heater once in awhile, for sure.
Best!
"Camp, or die trying!"
2013 r-pod 177
2008 Chry T&C
3.6 litre V6 - 6-speed
BillR
Direct Link To This Post Posted: 31 Mar 2015 at 9:44pm
I recommend putting it back in to prevent rust from forming on the threads.
Direct Link To This Post Posted: 31 Mar 2015 at 9:22pm
Probably can, our tech told us to take it out as part of winterizing. We use a plastic plug to close it up for the winter and then put the anode back in come spring.
kandk920 View Drop Down
Direct Link To This Post Posted: 31 Mar 2015 at 8:58pm
Originally posted by Leo B
It needs to be drained at the end of the season, you need to check the anode and remove it for the winter storage,  we got a plastic plug to screw into the hole so nothing crawls ( mice or spiders)in during storage.
Any reason why you can't just put the anode back in once the tank is drained?
2015 R-Pod 178
2008 Town & Country
Fox Valley, WI
Direct Link To This Post Posted: 31 Mar 2015 at 8:35am
You live in an area where winterization is probably not needed.. "owners choice" sort of thing.
However, I suspect you need to sanitize your freshwater system a little more often than owners who live in cooler, dryer, areas.
Belin View Drop Down
Direct Link To This Post Posted: 30 Mar 2015 at 8:40pm
Mandeville, Louisiana
Direct Link To This Post Posted: 30 Mar 2015 at 8:05pm
You may not have needed to. Where did your pod spend the winter??
I suspect somewhere near the gulf coast. If so, then winterization is not as big an issue.
Direct Link To This Post Posted: 30 Mar 2015 at 6:38pm
I didn't do that.
