When to dump? |
Post Reply | Page <12345 6> |
Topic: When to dump? Posted: 09 Apr 2016 at 8:47am |
There isn't any kind of air lock issue, the black tank is vented through the roof. The reason they don't want you to use the BWF with the valve closed is.. if you get distracted.. It will fill the tank.. then start filling the vent tube.. then start flowing all over the roof and outside of the pod. REALLY. It has happened. To pods I know. The exact same thing can happen with a hose in the toilet.. except the roof vent on the outside of the camper won't be the overflow point. The toilet will be. And that will be flowing all over the inside of the pod. OK, technically it will have to fill the grey tank first.. but, well, you forgot it already.. so.. All that said. I fill and flush a couple times, a couple times a year. I have FHU at home, so it's easy and convenient. I use the timer function on my phone (because I get distracted easy). It takes our hose about 5 minutes to fully fill the black tank.. At four and a half minutes or so, I open the dump. |
howmanyds
Groupie Joined: 07 Feb 2016 Location: Murrieta, CA Online Status: Offline Posts: 71 |
Posted: 09 Apr 2016 at 12:32pm |
That makes perfect sense.
And... Gross! |
Leo B
Posted: 09 Apr 2016 at 1:28pm |
Yup makes like a pod volcano!
Appocalexx
Groupie Joined: 01 May 2015 Location: AK Online Status: Offline Posts: 77 |
Posted: 26 Apr 2016 at 5:13am |
Did the owners rename their pod that after it happened? lol so gross. |
Posted: 26 Apr 2016 at 8:30am |
The
GLBCamper
Senior Member Joined: 30 Jun 2015 Location: Oregon Online Status: Offline Posts: 274 |
Posted: 26 Apr 2016 at 11:42am |
If the wall panel sensor is useless then what is a reliable way to know black water levels? (I don't care about the fresh water tank so much and have installed a voltmeter for the battery.)
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab New: 2016 EVO ATS 200rd 2016 F150 4x4 Sport |
Posted: 26 Apr 2016 at 12:13pm |
The wall panel sensor is not useless, just not precise. If you look at where the sensors are located on the tank, there is not much vertical space between the low and high sensors. The same thing goes for the fresh and gray water tanks. Full is only relatively full. There is additional space. However, if it is reading full, that would be a good time to dump before it reaches so high the toilet can't flush.
Keeping the black and gray water tanks cleaned out seems to be the best way to keep the sensors operating. If there is a build-up in one of the the tanks, it might cover the sensors to the extent that they can't detect the liquid levels. The fresh water tank is, of course, not (at least, it better not be) affected by this problem. There is no alarm to alert when the tank is full and in danger of overflowing. One must monitor the tanks. Adding an alarm might be a good mod to make if someone knows how to do it. I don't, so I will just monitor the levels. |
Posted: 26 Apr 2016 at 5:38pm |
When the "flush".. doesn't sound like a flush, you're full. With the two of us, we have gone 10 days until we "needed" to flush. Most of the time, a 3-4 day trip, we have to top off the BW tank to make sure we get a good dump. Then when we get home I usually flush and dump a full tank at least once, if we are not going back out in a week or two.. |
Posted: 26 Apr 2016 at 6:59pm |
Yup, when you see the black water rising up towards the toilet you are at the end. You might get one more flush. The gray water tank is full when the shower pan starts to fill up. Every camper I've owned, the sensors were useless on the black tank, and only somewhat useful for the gray and fresh tanks.
this_is_nascar
Senior Member Joined: 24 Jan 2010 Location: NJ Online Status: Offline Posts: 466 |
Posted: 26 Apr 2016 at 7:14pm |
Agree 100%. |
"Ray & Connie"
