  New Posts New Posts RSS Feed: removing 179 led light lense
Topic Closedremoving 179 led light lense
DHuse View Drop Down
Direct Link To This Post Topic: removing 179 led light lense
    Posted: 18 Feb 2015 at 3:33pm
All good now.  Who'd a thunk?  Thanks.
Direct Link To This Post Posted: 18 Feb 2015 at 2:32pm
Originally posted by DHuse
Good luck!
I see you changed your time offset setting, all good now?
Direct Link To This Post Posted: 18 Feb 2015 at 12:36pm
Good luck!
Greg Smith View Drop Down
Direct Link To This Post Posted: 17 Feb 2015 at 11:20pm
    DHuse My 2014 r- pod 179 is a Hood River Edition. You may have a 12 volt TV.
    I have decided to tap in the power for the DVD player. I will put the 12 volt receptacle beside the other outlets above the TV.
Greg
Direct Link To This Post Posted: 17 Feb 2015 at 9:58pm
Techntrek,
I posted the above post at 10:09 AM Pacific time.  I noticed your post says it came in at 4:00 PM.  In know the clock is correct on my computer, and I don't think you are 6 time zones ahead of me.  Can the time on this board be corrected?  Thanks
Doug
No problem with the server time, I'm making this post at 9:58 Eastern, and it is the time shown on the post.  Make sure your time zone is set correctly in your user settings (Member Control Panel).
Edit: and the post above that you referenced shows a post time of 1 pm, which is when I made it.
Direct Link To This Post Posted: 17 Feb 2015 at 3:48pm
I have the HRE.  That may be why 2 models of the same year are different.  The light may be your best bet.  Good luck.
Direct Link To This Post Posted: 17 Feb 2015 at 1:41pm
The connection points behind my TV are antenna, 120 volts, and video out, I have found 12 volts available behind the DVD player, but it may be easier to run the wiremold from the light.
Greg
Direct Link To This Post Posted: 17 Feb 2015 at 1:14pm
Techntrek,
Doug
Direct Link To This Post Posted: 17 Feb 2015 at 1:09pm
My /14 179 has a DC outlet behind the TV set over the bed.  To keep the television plugged into the DC outlet, you can buy a splitter cord that sends the 12 v in two directions.
Direct Link To This Post Posted: 17 Feb 2015 at 1:00pm
I wouldn't source the 12 volts at the light fixtures for charging.  Tap the wires coming from the converter and place 12 volt outlets where it is convenient to sit your phone.
