  New Posts New Posts RSS Feed: Still trying to get tv sound thru pod speakers
Topic ClosedStill trying to get tv sound thru pod speakers - Event Date: 24 Jan 2015
coledj View Drop Down
Direct Link To This Post Calendar Event: Still trying to get tv sound thru pod speakers
    Posted: 27 Jan 2015 at 2:56pm
I have taken all the replies received with bits from each one. I fixed the A B C speaker issue the factory wiring was wrong there are extra wires in there for more speakers. They wired 2 A speakers to A NONE TO b AND 2 FOR c. I cut the wires to one of the A speakers and attached wires for B speaker. Works great. In order to get all the pod speakers to work for tv I had to go ahead and use a mini cable from headphone jack on tv to a/v port on front of stereo. Not a hidden connection like i wanted but it also works great. Thanks to all for the help Dennis
Podster View Drop Down
Direct Link To This Post Posted: 26 Jan 2015 at 9:55pm
Originally posted by coledj
Using the mini cable it does work until I get tangled up in it the tv is on the curb side and stereo on the drivers side so cable cross the floor    thanks for everything
OK well, looks like some kind of wireless audio system it the ticket. Please come back and let us know how it works out. That's how we all learn here. Good Luck Sir!
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 26 Jan 2015 at 9:53pm
Originally posted by kymooses
My TV and Jensen system are the 12v in our Pod.
I thought were were talking like the DVD sound, the systems aren't usually set up to output the TV sound through the Jensen units and into the speakers.
It's certainly doable, would just take some piddling to take and Audio out from the TV and then into the Jensen.  That's why you're just seeing the yellow video out connection in your pod.
Lot of owners set up some wireless speakers I've seen.
Ahh, ok, well there you go. Thanks Travis!
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 26 Jan 2015 at 9:51pm
kymooses View Drop Down
Direct Link To This Post Posted: 26 Jan 2015 at 9:48pm
Direct Link To This Post Posted: 26 Jan 2015 at 9:43pm
I had talked to the dealer before because I did not receive a tv manual the dealer then sent me this manual. I have always had ? because I find no evidence of 12v the Jensen stereo awm968 the dvd player is in the stereo radio and when watching dvd sound comes thru all speakers just not on tv sound I did use the mini cable and it works just laid on the floor
OK, so for clarity, it is working now?
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 26 Jan 2015 at 9:30pm
Direct Link To This Post Posted: 26 Jan 2015 at 9:14pm
Oh wow...this is a first for me, a 12v tv with built in DVD in a POD? This tv retails for around $700.00. You can watch TV when off the grid. CoolWell I don't see blue tooth, can you send a pic of the face of the jensen stereo? You may have to run a mini audio jack from the tv audio out to the jensen audio in on the front panel of the stereo!
EDIT: You should be able to get some audio from the tv out and patch it into the jensen stereo in, however, it is very possible that that your configuration does not allow it.
Does anyone else out there have this av set up in their POD?
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 26 Jan 2015 at 8:59pm
TV model is Jensen je 1914 dvdc it is led the owners manual is listed under the 14 series
Direct Link To This Post Posted: 26 Jan 2015 at 8:38pm
What's the model of the TV.  Perhaps the two are bluetooth compatible with each other.
