coledj
Calendar Event: Still trying to get tv sound thru pod speakers Posted: 24 Jan 2015 at 6:31pm |
Jensen awm968 tried different things but still no tv sound thru stereo speakers only the tiny tv speaker any ideas ?
Podster
Posted: 24 Jan 2015 at 8:26pm |
Wish I had my pod here so i could look at the AV setup. Have you checked the tv menu? If not, check the sound setting on the tv and try different settings. This, of course, assuming you get music with no problem.
Cliff & Raelynn
Ranger 4.0/178
bonanddoug
Posted: 25 Jan 2015 at 12:57pm |
My 179 came wired 'backwards' (Jensen audio out to tv audio in). Had to move the RCA cables at the tv end and at the stereo. You need a #2 square driver to remove the jensen to access the back panel. Also the tv speakers have to be disabled through the tv menu. On our jensen the back panel audio in is selected as aux2.
2015 179 HRE
2014 Chevy Silverado 1500
coledj
Posted: 25 Jan 2015 at 2:04pm |
My stereo has coming out the back only. (1. ant cable) (1 rca yellow single hooked to video out) (and the 20pin connector with11 wires hooked and 9 wires just hanging), My tv has only (110 ac cord) (rca single yellow on wall plate tv video out to a/v the only yellow rca plug on tv )and the screw on cable rg6 from wall plate tv 1 to rf-in on tv)
Are we confused yet Thank you dennis
Podster
Posted: 25 Jan 2015 at 6:25pm |
All I can recommend at this point is to drill down on the manuals and/or find an AV specialist to trouble shoot it. Please come back and let us know how it turns out, that's how we learn here. Good luck, Sir.
Cliff & Raelynn
Ranger 4.0/178
2McPods
Posted: 26 Jan 2015 at 11:41am |
Originally posted by coledj
Jensen awm968 tried different things but still no tv sound thru stereo speakers only the tiny tv speaker any ideas ? |
1. Turn off Tv speakers in the Audio menu on tv.2. Then change audio from variable to fixed (this is grayed out until you turn off tv speakers) 3. On the back of tv make sure the white and red Rca cable is plugged into the audio out 4. Back of stereo switch Rca plugs to audio in 5. On stereo use the Aux 1 button when viewing tv
This came directly from Jensen stereo.
I hope this helps
Everything Happens 4 A Reason
Pat & Viki McCartney
2015 171 {2McPods}
2014 F150
Pittsburgh, Pa
coledj
Posted: 26 Jan 2015 at 2:34pm |
That sounds very easy to do. I wonder is Jensen assuming that all r-pods have these rca cables installed thru the body of the pod (my 2014 177 has only 1 rca type cable pre wired it is yellow from the back of stereo on video out to the wall plate marked tv video out then hooked to AV section that has 3 connectors marked V L R it came hooked in V . all of your rca cables are hidden in the walls aren't they Thanks to everyone very much for all the help
Podster
Posted: 26 Jan 2015 at 2:49pm |
...all of your rca cables are hidden in the walls aren't they |
No, you should see RCA cables from the plate to your TV. Y (video) W (L. Audio) and R (R. Audio).
Cliff & Raelynn
Ranger 4.0/178
coledj
Posted: 26 Jan 2015 at 5:40pm |
Thank you 1 photo is worth a thousand words that answered my question my 177 does not have that wall plate or rca cables any where in the trailer. it must matter what mood they are in on any given day. I see many things different on the same models. My only choice now is to try and run cables thru opening's inside the wall. I will run cables on the floor first to make sure it will work. Thanks for all the reply's
Podster
Posted: 26 Jan 2015 at 6:35pm |
I think all the PODs should have this setup, where did you get your POD? It appears they missed it when it was built!!!
Can anyone out there shed any light on this? Is there a version of a 177 that does not include an RCA plate on the entertainment wall for connecting he tv? I don't think so.
coledj, what year model is your 177?
Cliff & Raelynn
Ranger 4.0/178
