  New Posts New Posts RSS Feed: New Adventure
Topic ClosedNew Adventure
Direct Link To This Post Topic: New Adventure
    Posted: 06 Jan 2015 at 9:57am
Welcome to the group!
Podster View Drop Down
Direct Link To This Post Posted: 06 Jan 2015 at 9:17am
Congratulations on the acquisition of the new 179! Thumbs Up Looking forward to hearing about what you think about your new setup.  Be Safe and Have Fun!
Cliff & Raelynn
Ranger 4.0/178
retireclose View Drop Down
Direct Link To This Post Posted: 06 Jan 2015 at 8:21am
Welcome,  keep the diesel.  We have a 1/2 ton 2014 Silverado 1500.  We have the friction bar and no sway bar.  Made two trips this past summer to Smokies and Yellowstone.  Overall 13.3 mpg and no sway to speak of.  We also downsized from a 5th Wheel last year.  Takes time to get use to the smaller living quarters with two adults and a golden.  Safe travels.
Gary and Jill Winters
Bella Golden Retriever
2014 Silverado 1500
2015 R-Pod 179 -(SOLD)
JStrube View Drop Down
Direct Link To This Post Posted: 05 Jan 2015 at 10:58pm
Keep the diesel, leave the sway and lift bars behind.  I tow with a F250, no sway, no lift, don't even feel it back there, can get 13.5 mpg if I go 60, get 11.5 if I go 80.  Why go to anything lighter?  Sway and lift are overkill with a 3/4 ton.  Have towed many car trailers with double the weight without them.  Sometimes, if I forget to hit the tow/haul button, I can tell I have a load, but have climbed any CA grade easily.  If I wear it out, I might go to. 1/2ton, but until then, love the extra power.
2012 181G
Luv2Q View Drop Down
Direct Link To This Post Posted: 05 Jan 2015 at 10:28pm
Welcome!  And good luck as you get acquainted with the Podder side of life (though, with your experience, I somehow doubt you'll face many challenges!)  Smile
John & Teri
Tundra 5.7L V8 / RP 180
Pod4Two View Drop Down
Direct Link To This Post Posted: 05 Jan 2015 at 9:49pm
Welcome !
Ina & Philip Kennedy
2011 -177
2014 GMC Z71 4x4
LLSJKS49684 View Drop Down
Direct Link To This Post Posted: 05 Jan 2015 at 9:32pm
We are getting the sway bars based on the salesman's recommendation.  We are going with the Blue OX which looks pricey but the upside is the ease of use.  I had Reese with the Airstream and they were not always easy to use.
Thanks for the other info...downsizing has real appeal and opens the doors for flexibility on finding a place to park.
Larry and Jan
179 2015
2005 Silverado 2500HD Diesel
Direct Link To This Post Posted: 05 Jan 2015 at 9:28pm
Thanks!  We will keep the diesel for the next trip and then decide where to go from there.  We had a Tahoe before.  However we were pulling an Airstream and it was right on the edge for comfortable towing.
Larry and Jan
179 2015
Direct Link To This Post Posted: 05 Jan 2015 at 7:21pm
Welcome.  If you keep that diesel you'll never know the pod is back there.  If you are considering the Tahoe I'd step up to the Suburban to get the longer wheel base.  There is no difference in mpg between the two, and when we were pricing them used there was little difference in price.
Outbound View Drop Down
Direct Link To This Post Posted: 05 Jan 2015 at 6:42pm
Welcome aboard!  I hope you two enjoy your new r-pod.
The length is really convenient - you can fit on most campsites, and you can fit into a double parking spot at Walmart.
Some love the dome, others can do without it.  It is fairly easy to erect, and I can do it on my own in less than 10 minutes.  But, to be honest, I only put it up when I camped for a while and there's going to be poor/rainy weather, or when I'm camping with a group of people and we'll need someplace to gather.  The rest of the time, I use a simple awning which slides into the rail and uses two poles and guy ropes - but that's me.
As far as tow vehicle... my best advice is to chose something with at least 5000 lbs tow capacity.  I'll also caution that, although r-pods look aerodyamic, they're not.  Its an easy tow (although you'll want anti-sway, and perhaps WDH depending on your vehicle), but I suspect that your gas mileage won't improve as much as you expect compared to your 5'er.
The tire size on the r-pod is fine - they're well rated for the purpose.  No need to replace them.  You might want to consider adding some height with axle risers tho.
