GFCI Intermittent trip issue |
Post Reply | Page <12 |
CharlieM
Topic: GFCI Intermittent trip issue Posted: 14 Nov 2014 at 7:03pm |
Doug, What do you have in mind here? Other than overload or shorts, which should trip their breaker, I can't think of anything. |
Landry
Newbie Joined: 05 May 2013 Location: tampa Online Status: Offline Posts: 7 |
Posted: 14 Nov 2014 at 5:37pm |
Sorry, one more question - it appears that the GFCI in our 2013 rpod does not control the outlets where we plug the phones/chargers into nor the TV or Jensen system. Issues on these outlets would not impact GFCI, right? I assume a different circuit.
Camping at the Disney Ft Wilderness is an interesting experience - our little rpod with spacious rdome is surrounded by massive trailers and RVs with people watching 42" or larger flat screens outside. Sometimes it can be surreal...
R-Pod 176T
Pilot Ex-L |
Landry
Posted: 14 Nov 2014 at 5:30pm |
Thanks for all of the good advice. Now that the question was asked, and I think about it, the problem has only occurred at Disney. BUT, at home I only plug into a 20amp and we have only been to one other campground (don't laugh - we have a 7 year old daughter and annual passes to Disney).
Question - is there any type of device that we can use to protect from voltage issues if the problem is indeed at the campground? You say that problems with nearby RVs could be a problem for us. If this it true then what can we do about it? Any thoughts? BTW - I still plan to check out the downstream outlets in the rpod to make sure there are no problems there. Complicating matters is the fact that we park the rpod at a storage facility to avoid the tight squeeze we have had trying to park in our small urban lot. This makes troubleshooting that much less convenient. Thanks
R-Pod 176T
Pilot Ex-L |
Posted: 14 Nov 2014 at 10:26am |
First a question, have you ever had this problem when plugged in at home or at another campground? I agree it could just be a bad GFCI, but if you've never had a problem when plugged in elsewhere then it probably isn't the GFCI. As a rule, when they "nuisance trip", it is usually because there's a real problem somewhere.
Second, order the NCVT that fwunder linked to. Also buy a plug-in outlet tester (that has the 3 lights). The later will cost about $10. Then see the link in my signature. The first item in the list that pops up will explain how to use the NCVT and plug-in tester. USE THEM EVERY SINGLE TIME YOU PLUG IN - anywhere, even at home. I almost killed my kids before I started doing this. My hypothesis is not low voltage, but either a problem with the wiring at Disney, OR a problem with wiring of one of the other RVs at Disney. Yes, a wiring problem with another RV can cause problems with your RV. The other possibility is normal current leakage from things you have plugged into the GFCI circuit. If your phone charger is leaking 3 ma (normal), and your laptop power supply is leaking 2 ma (normal), then you are just at the 5 ma trip limit and anything else that leaks a bit will cause it to trip. |
Outbound
Posted: 13 Nov 2014 at 10:17pm |
My first thought is low voltage. Certainly a possibility if everyone in the campground is running their A/C.
My second thought is a loose wire on the GFCI or on one of the downstream outlets. Finally, I suppose it could be a wonky GFCI. If it's frustrated you enough, the price of a new one might be worth replacing it. Personally, I'd swap it with one from my house.
fwunder
Got one of these? It could save your life.
Landry
Posted: 13 Nov 2014 at 8:40pm |
The GFCI is actually connected to the outside outlet - the outlet even says GFCI protected. This is why I am stumped whether the issue is voltage related to the campground or possibly moisture in the outside outlet. My next step is to pull the outside outlet and look for signs of corrosion. I wish the rpod didn't tie many outlets together into that GFCI.
R-Pod 176T
Pilot Ex-L |
Hayduke
Groupie Joined: 03 Apr 2012 Location: Salt Lake, UT Online Status: Offline Posts: 68 |
Posted: 13 Nov 2014 at 8:28pm |
My guess is that it's not actually the GFCI. I think it's a situation of low voltage. We had a similar thing happen to us a few weekends ago when the power went out at our campground.
I don't think the GFCI is connected to the outside outlet. |
2012 177 HRE
2017 Tacoma Double Cab |
Landry
Posted: 13 Nov 2014 at 8:07pm |
As an unrelated point of interest - we towed our rpod for 1.5 years using a 15 year-old Honda Odyssey. This time was the last and the transmission was clearly not happy with its experience (we knew we were running it into the ground). Got 15 years out of the odyssey so we just bought a 4wd Pilot EX-L. Wish us luck...
Landry
Posted: 13 Nov 2014 at 8:03pm |
Hi All,
We have a 2013 176t. I am trying to diagnose an intermittent issue with the GFCI. The problem is that it trips periodically. I'll make a long story short, but hopefully not leave out important details. I think I am dealing with a lot of red-herrings and coincidences that are throwing me off from diagnosing the issue. The GFCI has only ever tripped while "camping" at Disney (ft wilderness). The first time it happened, we were plugged into the 30amp with the AC blowing (Florida...) and the fridge on ac, and lights on the exterior plug. I reset it, good for a short time, then tripped again. I unplugged the fridge then reset the GFCI and it was fine for two days (before going home). I dropped the Rpod at lazydays dealer on the way home. They tried to figure out the problem, decided to replace the board in the fridge, and we hoped everything would be good. This weekend we were once again at Disney in a full campground (always proud to be the smallest camper in a sea of monster RVs). The GFCI tripped again with no ac running but with the fridge running and lights connected to the exterior outlet. I unplugged the fridge, and could not reset the GFCI. Unplugged everything from the outside outlet and still could not reset the GFCI. Tried several time. Also tried unplugging the 30amp, still no luck. Now it gets weird or red-herring territory - the next day, after many of the monster RVs moved out around us, the GFCI could be reset and stayed that way for a day before we left. So, what do you think the problem is here: 1. Problem with the power in the campground (remember this is Disney). 2. Problem with the GFCI - are there actually good and bad GFCIs? 3. Could it be a problem with one of the outlets attached to the GFCI - maybe the exterior outlet was damp the first day and then dried out after that? 4. Other thoughts? This is perplexing, so any advice is appreciated. Cheers |
