In reading the owners manual on that subject I end up being a little confused. Under "Battery Charging" it states that the converter also operates as a battery charger when it is connected to a 110 power source. It goes on to say that when charging a battery follow these safety precautions. A total of four, the first being to disconnect the battery from the RV. Is that intended ffor charging your battery ex the converter?
Under "Power Converter". The converter is used to switch 110 volt electricity from an external supply or from a generatorto 12 volt electricity. Does the converter, when connected to 110 volt recharge my battery directly?
Thanks for your response.
Larry158
