AC/HEATER PROBLEM - WALL COMPONENT - Event Date: 11 May 2014 |
teamlacaro
Newbie Joined: 29 Sep 2014 Online Status: Offline Posts: 5 |
Calendar Event: AC/HEATER PROBLEM - WALL COMPONENT Posted: 06 Nov 2014 at 11:36am |
Thank you
Team LaCaro RPOD Enthusiast
teamlacaro
Posted: 06 Nov 2014 at 11:35am |
Did what you suggested and it works great. Thank you!
Luv2Q
Senior Member Joined: 30 Aug 2014 Location: Central TX Online Status: Offline Posts: 309 |
Posted: 05 Nov 2014 at 8:35pm |
On mine:
You're done. Now, when the heater comes on, the blower on the a/c will stay off. |
John & Teri
Tundra 5.7L V8 / RP 180 E2 WDH / Integrated controller (POS) replaced by Tekonsha P3 |
Posted: 05 Nov 2014 at 5:04pm |
I had it backwards. See this thread for a discussion (set it to Auto, not High or Low).
teamlacaro
Posted: 05 Nov 2014 at 4:08pm |
Thanks for the quick response. I was so preoccupied with the fan I didn't even check to see if the heater went on. I will check tonight.
Posted: 05 Nov 2014 at 3:01pm |
Check the thermostat to see if the fan setting is Auto. With the digital thermostats that will allow the A/C fan (not the compressor) to run at the same time as the heater. I agree with Fred that it can be annoying, although there have been times when using the A/C's fan at the same time helped to get the heat more evenly distributed.
fwunder
Posted: 05 Nov 2014 at 2:55pm |
Hi teamlacaro,
Are you sure the AC fan *and* the heater didn't come on? Personally, I find that annoying and simply turn the AC fan off by turning the AC breaker on the electric panel off. fred
teamlacaro
Posted: 05 Nov 2014 at 2:36pm |
Hi...hope i can get some much needed advice. I tried turning on the heater in our RPOD 176 the A/C turns on instead. We have a Domestic Wall Component. Help!Thanks TeamLaCaro
