2McPods
Topic: Black tank flush winterization Posted: 02 Nov 2014 at 1:58pm |
Originally posted by wildfire305
Also remember to close all of your faucets before doing this and open them afterwards. Always store the pod over winter with open faucets.
We winterized with the pink stuff, do we still need to open all faucets over winter?
Thanks, Viki
Everything Happens 4 A Reason
Pat & Viki McCartney
2015 171 {2McPods}
2014 F150
Pittsburgh, Pa
MoggerPod
Posted: 02 Nov 2014 at 9:33am |
On my 177, the inlet for the tank flush is elevated above floor level. This line drops under the floor and then up to the check valve located near the bathroom sink. That entire section of line will hold water if not blown out during winterization.
Brad & Laura B.
Durango, CO
2014 RP177HRE
kymooses
Posted: 01 Nov 2014 at 9:24pm |
No need to do anything to the black tank one. The valve has a gravity ball in it. What doesn't drain into your black tank when using it, falls back out the line when you're done. You'll always notice when you disconnect it that water will run back out of it.
I've specifically asked Forest River this question because I was curious about mine years ago when they first launched.
wildfire305
Posted: 01 Nov 2014 at 2:02pm |
The fresh water also has a check valve. But you can bump the little button on the center of the hose connection under pressure with pink and that will solve that too. Some disagree, but I also put a gallon in the fresh water tank to pinkify the suction line to the pump.
2005 Dodge Durango 4.7 V8
OLD Tow Vehicle 2004 Honda Odyssey
2015 RP179 "73b"
OLD 2005 Viking Saga 2480ST popup
RescapePod
Posted: 01 Nov 2014 at 1:46pm |
Thanks wildfire305
2015 R-Pod 179
2013 Chevy K1500
wildfire305
Posted: 01 Nov 2014 at 1:31pm |
Yes. but I don't think it's necessary, five minutes of compressed air would dry the pipe. However, if you do not have access to a compressor then... Get a 1/2 female iron pipe by 3/4" male garden hose threaded adapter (large box store or plumbing supply). Connect that to your blue low point drain. Connect a clean garden hose from the low point drain to the black water flush. Put another gallon of antifreeze into the winterization hose under the bed and turn on the pump. It will pump it from the antifreeze bottle, through the low point, out the garden hose and into the black flush line. Also remember to close all of your faucets before doing this and open them afterwards. Always store the pod over winter with open faucets.
2015 RP179 "73b"
RescapePod
Posted: 01 Nov 2014 at 1:15pm |
Is there any way to get pink stuff to it?
2015 R-Pod 179
2013 Chevy K1500
wildfire305
Posted: 01 Nov 2014 at 12:46pm |
There is a check valve on the hose connection and a vacuum breaker inside behind the sink. That one foot section will hold water unless it is dealt with. Perhaps that is why so many people have leaks on that section besides forest river installing the vacuum breaker backwards.
2015 RP179 "73b"
wildfire305
Posted: 01 Nov 2014 at 12:44pm |
I blew mine out with compressed air for 5 minutes using a compressor hose adapter.
2015 RP179 "73b"
Posted: 01 Nov 2014 at 12:43pm |
You are the first to ask as far as I know. The system empties into the black tank. so it should be empty/drained already. there is a backflow preventer, but I am not sure on it's specs. I guess I would physically look to see if it was holding any water on the outboard side of the valve.
