Break Light Flashes - Event Date: 01 Sep 2014 - 10 Sep 2014 |
Post Reply | Page 12> |
vnapoli
Newbie Joined: 04 May 2014 Location: hurley, ny Online Status: Offline Posts: 10 |
Calendar Event: Break Light Flashes Posted: 01 Sep 2014 at 7:54pm |
I have a 2014 RPOD 171 and on our recent trip my wife who was following me said that when I applied my breaks my left break light flashes as though I was making a turn. This only happen when the vehicle in running. In addition, the speed of the flashing is slower than a turn signal.
So my question is: Is the left one flashing when it shouldn't or is the right one not flashing when it should? Thanks in advance. |
Vince and Debbie
R Pod 171 Tacoma 4x4, regular cab, 4 cylinder |
Hairy Podders
Senior Member Joined: 05 Mar 2014 Location: Northwest Ohio Online Status: Offline Posts: 217 |
Posted: 01 Sep 2014 at 9:12pm |
Sounds like a bad logic module light controller on the truck. If yours has one. IE: If your truck has separate brake light & turn light bulbs on each side, then you truck has to have a logic module to adapt that system to the single brake/ turn light bulb on the Rpod. Sounds like that little black box is bad. Or it may have a poor ground.
Darryl, Julie & Lindsey
Cooper & Libby- Devoted Canines 2014 RP178 2006 Wrangler Unlimited Rubicon |
Outbound
Posted: 01 Sep 2014 at 9:32pm |
If your running lights are on while you're breaking with the turnsignal, then yes, it might look like your description; but that'd be it. Except, the flashing frequency shouldn't be noticeably slower - well, not on a truck built in this century (wow, it feels very strange saying that); a 90s truck's flasher might slow down a bit due to the voltage drop from powering all the lights.
Posted: 02 Sep 2014 at 5:58pm |
I agree it sounds like a problem with the tail/turn light combiner. When mine went bad both brake lights flashed exactly like a turn signal. Be careful to order a new one that supports LED lights, not all can drive LEDs.
vnapoli
Posted: 02 Sep 2014 at 8:37pm |
Thanks. The unit is under warranty so I'm expecting my dealer to replace it when I take it back for other warranty work.
Vince and Debbie
Posted: 03 Sep 2014 at 8:46am |
This would be mounted on your tow vehicle, so not a pod warranty item. However, if they installed it then I would ask them (or whoever did install it) to replace it.
vnapoli
Posted: 07 Sep 2014 at 7:04am |
I've isolated the problem to the truck by using my sons truck as a test and the brake lights on the RPOD don't flash.
The only black box I can find is the electric brake controller. Where do you think the combiner would be installed? |
Vince and Debbie
Hairy Podders
Posted: 07 Sep 2014 at 7:09am |
Start at the trailer plug on the truck & work your way forward following the wiring. Usually they are under the back of the vehicle. But it could be under the dash too.
vnapoli
Posted: 07 Sep 2014 at 7:19am |
How large of a unit am I looking for? There is a flat wire going into the trailer plug. I originally had a 4 hire connector and when I got the RPOD they converted it to a 7 pin.
Vince and Debbie
Hairy Podders
Posted: 07 Sep 2014 at 11:07am |
Approximately the size of a large pack of gum, and half as thick.
