Break Light Flashes - Event Date: 01 Sep 2014 - 10 Sep 2014 |
Post Reply | Page 12> |
Hairy Podders
Senior Member Joined: 05 Mar 2014 Location: Northwest Ohio Online Status: Offline Posts: 217 |
Calendar Event: Break Light Flashes Posted: 08 Sep 2014 at 8:41pm |
And to make it a worry free installation, use heat shrink butt connectors at every connection. Saves a lot of corrosion issues down the road, literally.
Darryl, Julie & Lindsey
Cooper & Libby- Devoted Canines 2014 RP178 2006 Wrangler Unlimited Rubicon |
Hairy Podders
Posted: 08 Sep 2014 at 8:39pm |
^^ What he said...^^
Posted: 08 Sep 2014 at 5:33pm |
Bingo. I would just replace it. The flashing lights were your test.
vnapoli
Newbie Joined: 04 May 2014 Location: hurley, ny Online Status: Offline Posts: 10 |
Posted: 08 Sep 2014 at 6:25am |
I found it. Dealer installed. It was behind the brake light assembly. Any way to test the unit? or just replace it?
Vince and Debbie
R Pod 171 Tacoma 4x4, regular cab, 4 cylinder |
Hairy Podders
Posted: 07 Sep 2014 at 11:07am |
Approximately the size of a large pack of gum, and half as thick.
vnapoli
Posted: 07 Sep 2014 at 7:19am |
How large of a unit am I looking for? There is a flat wire going into the trailer plug. I originally had a 4 hire connector and when I got the RPOD they converted it to a 7 pin.
Vince and Debbie
Hairy Podders
Posted: 07 Sep 2014 at 7:09am |
Start at the trailer plug on the truck & work your way forward following the wiring. Usually they are under the back of the vehicle. But it could be under the dash too.
vnapoli
Posted: 07 Sep 2014 at 7:04am |
I've isolated the problem to the truck by using my sons truck as a test and the brake lights on the RPOD don't flash.
The only black box I can find is the electric brake controller. Where do you think the combiner would be installed? |
Vince and Debbie
Posted: 03 Sep 2014 at 8:46am |
This would be mounted on your tow vehicle, so not a pod warranty item. However, if they installed it then I would ask them (or whoever did install it) to replace it.
vnapoli
Posted: 02 Sep 2014 at 8:37pm |
Thanks. The unit is under warranty so I'm expecting my dealer to replace it when I take it back for other warranty work.
Vince and Debbie
