Under the Sink |
3ofUs
Groupie Joined: 12 Jul 2014 Location: TN Online Status: Offline Posts: 99 |
Topic: Under the Sink Posted: 29 Jul 2014 at 8:46pm |
We pulled that back wall in the small cabinet tonight, and although there is quite a bit of open space, every thing is fixed, no play to electrical and we decided to just close it up. I don't travel with all the array of cast iron like some. Gave that up a long time ago. At least we found out what was behind there and it was clean. Thanks for your input and if we have need, I guess we will go back and revisit that space.
ron_whitt
Senior Member Joined: 08 Sep 2011 Location: Chesterville On Online Status: Offline Posts: 261 |
Posted: 29 Jul 2014 at 7:44pm |
We have the 177. I removed both panels and the floor you see (in the 177) in front of the panels goes all the way to the outside wall. There is an immense amount of room back there. I put a small plastic bowl over the electrical relay.. to protect it and cut small access holes for the wires and to allow for air movement over the relay. We also put an outside shower there and still have tons of room for storage under the sink. Any wires etc. there just move them off to the side and tie them together. Good luck.
Ron & Shirley
2020 Tacoma 2012 177 rpod |
3ofUs
Posted: 29 Jul 2014 at 7:32pm |
As a follow-up to my previous post, we have a 2011 182G.
Posted: 29 Jul 2014 at 5:05pm |
There are many areas where this is true, but the locations differ depending on model - and model year. For instance, on my early 171 they divided up the front-left under-seat storage between the converter (lid screwed closed) and open storage (lid hinged). More recent model years left it all inaccessible unless you modify it yourself. Even on my model year I've found several areas where you can create more storage by removing panels (under the fridge, and under the bed). Some areas you must be careful due to wiring or piping, as you thought.
If you add your model and year to your signature someone here should be able to help with your specific situation.
3ofUs
Posted: 29 Jul 2014 at 2:28pm |
Any one not on the road to Goshen besides me and can tell me what is holding that thin panel under the sink to form the back wall of that small cabinet? Don't care to rip it out. Want to see what is behind it. I know pipes and probably electrical, but does it drop down to the floor of the pod or is there a shelf behind it? I know I saw somewhere owners were able to increase storage. Thanks.
