I made an expensive mistake |
Post Reply | Page <12345 6> |
spacemonkey
Newbie Joined: 04 Oct 2013 Location: TX Online Status: Offline Posts: 32 |
Topic: I made an expensive mistake Posted: 20 Jul 2014 at 5:22pm |
Thanks CharlieM. I think your probably right. Im going to just order another converter and be done with it. Im ready to go camping...haha
CharlieM
Posted: 20 Jul 2014 at 5:23pm |
Do the ceiling lights work at approx. normal brilliance? Are they LEDs or incandescent? If yes, the pump should work too. If not, you may be right about the battery. Do you have a voltmeter?
Cap-n-Cray
Senior Member Joined: 22 Feb 2014 Location: Bainbridge Is Online Status: Offline Posts: 121 |
Posted: 20 Jul 2014 at 5:24pm |
Since the pump is 12V it probably was not effected. Can you jump another battery to your pod's battery or put a charger on it? |
Cary
2014 RP-177 |
CharlieM
Posted: 20 Jul 2014 at 5:31pm |
I'm a EE and could easily attempt the repair........but I wouldn't. I really like the PD much better. You're on the right track. I'd rather go camping too. |
spacemonkey
Posted: 20 Jul 2014 at 10:28pm |
yes the ceiling lights work. they are incandescent. I tested the battery with my voltmeter and its putting out 12.5 volts. maybe this is just an unrelated bad pump. I will get it figured out.
Now for the TV. So sorry to keep posting up more stuff, but you guys have been so much help so far. I pulled the TV apart, and I think your right about the fuse being blown. Lets hope that is all that is wrong. Below are some pictures. Here is the circuit board where the power cord came into the TV. I removed the cord from the white connecter at left in order to expose what I believe is the fuse that is blown. It says T2.5A 250V on it. Where can i get a replacement like this? Radio Shack? I did a continuity test on it and got nothing. I have never tested a fuse of this sort before, but I assume the way I did it in the picture below should show continuity if the fuse was still good? In this picture you can see what looks like a little black soot around the fuse. Kind of a dead giveaway to me that this is likely my problem. Whats your thoughts? I am going to give this a whirl. I understand soldering. I have soldered electronics (mostly wires and pots) on electric guitars, but have never done anything on a circuit board. Ill see if i can find some good youtube vids on it too. Cant hurt to try. If i dont...the TV is toast anyways and I will still have to buy a new one. If I succeed, then i saved myself several hundred bucks on a new one. I just need to find the fuse. Do yall think radio shack will have them? |
Cap-n-Cray
Posted: 20 Jul 2014 at 11:45pm |
I believe that is a slow blow fuse, 2.5 AMPS, 250V. That also explains the blow out black.
http://www.ebay.com/itm/MULTICOMP-MST-T2-5A-250V-FUSE-SLOW-BLOW-8-335MM-LOT-OF-5-NNB-/151160015830?pt=LH_DefaultDomain_0&hash=item2331d6cbd6 There might be a cheaper one elsewhere. Anything else look damaged? |
Cary
2014 RP-177 |
Cap-n-Cray
Posted: 20 Jul 2014 at 11:51pm |
Here I found some...
http://www.ebay.com/itm/20-pieces-250V-2-5A-Square-Slow-Blow-DIP-Mounted-Micro-Fuses-8-4-8mm-/171338345866?pt=LH_DefaultDomain_0&hash=item27e48fad8a Of course you will be the keeper of the TV fuses for Rpods... |
Cary
2014 RP-177 |
Budward
Senior Member Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
Posted: 21 Jul 2014 at 5:27am |
If it was me- I'd jump that fuse with a very small wire, soldered across the two spots you measured at.
If the TV works then hunt down the proper fuse, if the strand burns out or the tv doesn't work, stop there and head to the trash can. Again this is what I'd do...YMMV and all that. |
2014 179
Towed by a 2015 Ford Transit Diesel Supervised by a German/Aussie mix and a Labradoodle! |
CharlieM
Posted: 21 Jul 2014 at 9:08am |
I tend to agree with Budward. If the TV works the fuse protected the rest of the components and you are lucky. Use a small piece of wire like a single strand from a larger stranded wire. If it doesn't work nothing lost. Replacement fuses are available, cheaper than Ebay, from Amazon : http://www.amazon.com/Mounted-Miniature-Square-Micro-T2-5A/dp/B009PMJ082/ref=sr_1_6?ie=UTF8&qid=1405946333&sr=8-6&keywords=t2.5a+250v or Newark: http://www.newark.com/multicomp/mst-2-5a-250v/fuse-pcb-2-5a-250v-slow-blow/dp/95M6782?mckv=s5hvSBoxr|pcrid|45121758995|plid|&CMP=KNC-G-SKU-MDC However, having had the TV in my 172 and judging by comments from others, I wouldn't invest a lot in it. It was a 7 or 9 inch under counter piece of junk. That was the only option I regretted ordering with the Pod. I'm not sure if the TV in the 179 is the same or the 19" model. The water pump remains a mystery. If you hear noise it might be running. Check for a clogged filter, broken or disconnected hose. Loose hose fittings have been reported which would let the pump suck air. |
CharlieM
Posted: 21 Jul 2014 at 2:12pm |
Let me quote from a new post by Obewan on RV.Net.
"Was gone from the camper for a couple days and missed all the excitement! Neighbors tell me the campground experienced a large electrical surge. They lost tvs, small appliances, AC units, etc.. I lost NOTHING! Surge protector apparently worked as designed and I'm very glad I spent that money! Already recouped the cost in not having to replace anything! Smiling in an AC camper while I watch tv!!!" They had the plugin 30A SurgeGuard. 'Nuff said. |
