  New Posts New Posts RSS Feed: 12 VDC outlets and shore power
Topic Closed12 VDC outlets and shore power
cody91 View Drop Down
Direct Link To This Post Topic: 12 VDC outlets and shore power
    Posted: 24 Jun 2014 at 11:07am
I recently installed a 12 VDC outlet on my 178 to use when camping without hook ups.  Are there any issues with using the 12 outlets when connected to shore power?  I have some small appliances that use the 12 VDC outlet (i.e. small cooler, air pump, radio, etc.).
Thanks,
Cody91
Direct Link To This Post Posted: 24 Jun 2014 at 12:37pm
Nope, no problems.  Ultimately the power will come from the converter when you are plugged in.  This will mean it is slightly higher - maybe 13.5 volts instead of 12.5.
CharlieM View Drop Down
Direct Link To This Post Posted: 24 Jun 2014 at 12:41pm
Assuming you installed it properly with at least #14 wire, preferably #12 or #10, no problem at all. Your converter will supply the 12 volt outlets while maintaining battery charge. Shore power will run your 120 volt appliances like A/C and microwave.
Direct Link To This Post Posted: 24 Jun 2014 at 1:22pm
Thanks for the response guys. I used 12 gauge wire.  I also you the outlet to check the voltage with a plug in meter.  It works great.
