How low of temps before freezing plumbing? |
COSPod
Newbie Joined: 20 Jan 2014 Online Status: Offline Posts: 38 |
Topic: How low of temps before freezing plumbing? Posted: 12 Jun 2014 at 12:01pm |
We'll be camping up around 9K feet this weekend, and it's looking like it could dip down to, or slightly below freezing for a few hours saturday night. My guess is 30-32 for a 3-4 hours. Given it'll be in 50s/60s, and sunny during the day, what is the level of concern I should have over tanks/plumbing freezing? My thinking is the residual heat will be enough to keep the water in tanks and plumbing from freezing, or at least freezing enough to cause problems. Am I correct in my thinking there??
Alternately, would opening low point drains sat night to drain out most of the plumbing be helpful and/or good cautionary step? I don't anticipate much need for water after saturday night as we leave sunday morning. Alternately would running water a couple times over night be enough? Thanks |
Posted: 12 Jun 2014 at 12:43pm |
The only thing that will be exposed to those temps are the tanks and the fresh water line to the pump. Those temps for a few hours will be fine, especially if the fresh water tank has water in it. Water has a lot of thermal carryover so nothing will come close to freezing.
My recommendation for the fall is, if it will get below freezing by more than a few degrees and by more than a few hours, it is time to winterize. But then your pod will be sitting w/o water and w/o any heat inside.
Outbound
Posted: 12 Jun 2014 at 6:32pm |
You'll be fine. In the fall, I camp all the time in Algonquin when the temperature drops below freezing for a few hours overnight. Occasionally, I'll wake up to a couple inches of snow on the ground
As Doug said, make sure you've got water in your fresh tank (I'd suggest at least 1/3 full) - the thermal mass will keep it from freezing in that short of a timeframe. Make sure you've got a full tank of propane - at those temperatures, you can go through a tank in 3-4 days.
Tars Tarkas
Posted: 12 Jun 2014 at 8:23pm |
I agree. We've been out in the mid to low 20s and did okay. Upper 20s should be no problem at all. If you want you can get up and run the water for a couple of seconds a couple of times. Cheap insurance would be to also take of the paneling in front of the water heater/pump/sink, but you should be fine.
TT |
FJ Cruiser |
COSPod
Posted: 12 Jun 2014 at 10:34pm |
awesome info as always, thanks!
