trailer jack wheel |
sammycamper
Senior Member Joined: 23 Oct 2012 Location: Minnesota Online Status: Offline Posts: 111 |
Topic: trailer jack wheel Posted: 26 May 2014 at 10:07pm |
Sam
2012 rPod 173
2008 Trailblazer 4WD V6 |
Markus5
Newbie Joined: 02 May 2014 Online Status: Offline Posts: 25 |
Posted: 23 May 2014 at 11:49pm |
I put a flat pad on. You don't need a block in many cases. It does slide a bit if you need to horse it around. Bad for the back I suppose. But you can do it.
Camper Bob
podders Helping podders - pHp Joined: 26 Sep 2011 Location: Portland Oregon Online Status: Offline Posts: 913 |
Posted: 22 May 2014 at 8:49am |
We, upon receipt of our 171, replaced the jack with a Bal swiveling jack and wheel that attach to the side of the frame. Works just fine. Easy to move trailer when hitch is just a tad off the mark. Easy to move on our driveway to park it. Whole unit about $50. on Amazon. Safe Travels.
Camper Bob and Camper Sue
jan demarinis
Groupie Joined: 22 Apr 2014 Location: Northern CA Online Status: Offline Posts: 54 |
Posted: 21 May 2014 at 10:25pm |
Just bought an aftermarket wheel. Thanks for the reminder about being level. I could just see the pod rolling away...
ToolmanJohn
Posted: 21 May 2014 at 10:23pm |
Make sure to only use it on a level surface. If you remove a wheel chock on an incline with a bogey jack wheel on the jack, the trailer will move.
Craneman
Senior Member Joined: 12 May 2013 Location: Tokeland,wa Online Status: Offline Posts: 387 |
Posted: 21 May 2014 at 1:43pm |
I use a wheel on my 174 and it moves easily on concert floor .
Moe
Jo and Gary 2010 174 2011 Ford 150 |
Posted: 21 May 2014 at 12:31pm |
Welcome. You should be able to add an aftermarket wheel, like one of these.
waltFD
Newbie Joined: 20 May 2014 Online Status: Offline Posts: 2 |
Posted: 21 May 2014 at 12:21pm |
Used to pulling a tent trailer and use a wheel on the jack when parked. Noticed on R Pods that they don't have a wheel and the front jack is on a block of wood. We like the wheel - easier to get the trailer on the truck and to make slight adjustments when parked. Does anyone use a wheel? Is the R Pod too heavy to use a wheel?
Thanks for any info. |
