Sure Sign Of Spring! |
Post Reply | Page 12> |
Hairy Podders
Senior Member Joined: 05 Mar 2014 Location: Northwest Ohio Online Status: Offline Posts: 217 |
Topic: Sure Sign Of Spring! Posted: 14 Apr 2014 at 12:22pm |
I remember sickle mowers! In fact I have a 4'sickle mower attachment for my Cub Cadet. It works great for mowing under pine trees. It can also be used vertically, so you can trim along hedgerows & lanes. I use it every fall.
Darryl, Julie & Lindsey
Cooper & Libby- Devoted Canines 2014 RP178 2006 Wrangler Unlimited Rubicon |
Posted: 13 Apr 2014 at 10:08pm |
Oh I'd love me some bucket action! In fact I'll need to rent a Bobcat soon to move some dirt around.
Old Dingo&Mrs.Dingo
Senior Member Joined: 07 Jul 2012 Location: Tarentum, PA Online Status: Offline Posts: 138 |
Posted: 12 Apr 2014 at 6:46pm |
Our's are a little bigger, but your Deere is a lot younger! Front loaders are handy, but at this class of tractor they're just "motorized wheel barrows." I'd love to have a 1200 series, but I can't justify replacing my old 445.
Old Dingo and/or Mrs. Dingo
181G 2013 Jeep Grand Cherokee |
fwunder
Posted: 12 Apr 2014 at 5:56pm |
You guys got bigger deere's than I do. Just got mine out of hibernation yesterday. New fluids and filters and ready to go. Turned 770 hours today. If I need something bigger, I just borrow neighbor's big Kubota. I do have bucket envy!
My x300: |
Posted: 12 Apr 2014 at 5:40pm |
I have a 2" ball on my Deere (a 318), which I use to tow around my big utility trailer. I did move my heavier-than-the-pod popup with it but never the pod since it is so low. Didn't have any problem with wheelies or forward traction but it definitely pushed me around when I tried to stop.
Old Dingo&Mrs.Dingo
Posted: 12 Apr 2014 at 4:53pm |
No doubt about it, a Gravely is a work horse. My Deere has about 1250 hours on it, runs like new, I'm a stickler for maintenance. I find if I run the Deere off the concrete with the pod on the back, even with agricultural tires & diff lock, I dig holes trying to back uphill. When I try to pull uphill, I get wheelies. That's why we use the jeep off the concrete.
fwunder
Posted: 12 Apr 2014 at 2:50pm |
Yeah, the Gravely is a brute. Just put new tires on it last year. It only has 180 hours on it and runs like a champ. Elderly neighbor gifted it to me. I found the sulky last year too. Brings back childhood memories and helps me keep a couple of acres of "woods" under control. Not much it won't chop through. As scary as it is, it's not as medieval as the old Toro sickle mower I got! Remember sickle mowers?
I use the deere with a couple of different utility "clean-up" trailers and just ordered a Hitchin Post ( http://www.amazon.com/Good-Vibrations-170-Hitchin-Connector/dp/B003L77Z8Y ) for it. It will be fun to see if I can maneuver the pod around a bit with it. Figured I want to get the load as close to back axle as I can. Between tractor and my 200+ lbs (Arghhh), maybe I won't spin the wheels too bad. The break away cable close at hand is a good idea. Also, I think I'll put the Jack wheel for potential wheelies! Yes, I will post pictures if you promise not to laugh!
Old Dingo&Mrs.Dingo
Posted: 12 Apr 2014 at 10:20am |
BTW Fred, in our valley we still call Gravelys, "man-killers". If you are worried about the pod getting away from you, just pull the "break away" cable. On the level driveway we use a 445 Deere (22 hp) with a sturdy 2" receiver hitch on the 3-point to move our 'pod and it allows us to use a cargo carrier to move other "miscellaneous stuff" around home. Pod transport requires front weights if you want to steer without the mower or loader installed. If we have to move the 'pod over longer distances (or off the concrete) we use our JK Wrangler.
Leo B
Posted: 12 Apr 2014 at 7:13am |
Still waiting for snow banks to melt and mud to dry up :(
fwunder
Posted: 11 Apr 2014 at 6:46pm |
Deere's are nice machines. I have a Deere x300 (17HP - not big box model) thinking about fabricating a hitch to drag pod around. I'm sure it would pull it. Stopping it could be a problem. Wonder if a 12v break controller could be rigged?
