GENERATOR - Event Date: 27 Feb 2014 - 27 Apr 2014 |
Post Reply | Page <1 23456 12> |
Author | ||
Calendar Event: GENERATOR Posted: 04 Mar 2014 at 7:51pm |
I tried to look at one in person today, even though I REALLY hate the orange box.
And they did not disappoint. Website said my local store had 7 in stock. PRINTED the page and took it with me. Had to talk to five, YES 5, associates before anyone knew where "Aisle BW, Bin 3" was. Guess what..? that's right, big freaking empty space, labeled, right where they are supposed to be. NONE on order. WHY you ask? Because the "system" shows eight in stock, so it won't order until "stock gets low". I kid you not. I hate that place. |
CharlieM
Posted: 04 Mar 2014 at 7:43pm | |
The cheap adapter is filled with unobtanium encased in raw Chinium. |
CharlieM
Posted: 04 Mar 2014 at 7:40pm | |
Definitely concur. I don't think anyone has suggested the generator backfeed the house through the Pod. I suggested that, if the house is wired properly with a transfer switch and a 30A outlet for the Pod, you'd be set up to run the pod from the house without any special adapters. |
HuronSailor
Posted: 04 Mar 2014 at 7:33pm | |
Good question. I looked at web site of the company that furnishes Home Depot's adapter and there just ain't much information there. I haven't done any more research than that as of yet. I am curious about their internal guts. How do they convert 220 to 110? Do they have a tiny transformer inside? A bank of resistors? A blob of Kryptonite? Do they just tap one leg of the 220 output and run all imbalanced?! For $13 I might buy one from Home Depot and dissect it.
Posted: 04 Mar 2014 at 6:31pm | |
I think the danger of counting on the main breaker being tripped to prevent electrocution of a lineman has been covered, but with the suggestion that the generator backfeed the house through the Pod makes me once again state that should for some reason even with the best of intentions the breaker doesn't get flipped and someone gets hurt you will be responsible and most likely spend lots of money and time in court. The cost of a real transfer switch is small in comparison. I strongly suggest not to play with fire. I read about this type of accident at least once per year when a well meaning person made a mistake.
Posted: 04 Mar 2014 at 2:55pm | |
As has been mentioned, that adapter will work fine. However, you might just want to use a standard "hockey puck" adapter that allows you to plug into a standard 15 or 20 amp outlet. That's all I use on my small genset. You can only run one of the big items at one time - A/C or microwave or electric element in the water heater, but it will work.
CharlieM
OK. I get it. And, as I say to our servicemen/women: Thanks for your service.
Posted: 04 Mar 2014 at 2:51pm | |
You are correct that L1 and L2 when tied together have no voltage potential. Many 240 volt loads aren't strictly 240. Some driers and washer/drier combos require 120 for the control board and nightlights on the door frames. In an older home that only runs L1, L2 and ground to the drier plug (3 pins and not 4) this is fudged by using the ground as the neutral since they are tied together at the utility panel. Things like well pumps can leak current to ground if there is a fault in the wiring. If you only supply 120 via one leg and neutral or ground things can overheat since the item can't start or operate properly.
No issues with the wandering discussion - for starters this is in the Misc/Off-topic sub-forum. Second, discussions change in the natural course of things, it happens. It really ticks me off on other forums when mods lock threads or delete posts because they wander a little off topic.
hogone
Senior Member Joined: 09 Apr 2013 Location: St. Louis Online Status: Offline Posts: 1043 |
Posted: 04 Mar 2014 at 9:16am | |
Huron: Should I try the one from home depot for 12.97, or the camco #55382 for $26 (which appears to be the same/similar as the one on the campers world site(#69589) but 20 bucks cheaper)?
Jon & Pam
HuronSailor
Posted: 04 Mar 2014 at 8:59am | |
Plus as I said before you would have full use of all your rPods appliances, just as if you were plugged into the power at a campground, with no spaghetti mess of extension cords running through the door. Go buy the adapter and try it out for me, will you? I'm dying to know how it works! - - - - - - - - - - - - - - P.S. I have a ten circuit manual transfer switch in my basement next to the distribution panel, and a 30A generator inlet on the outside of my house. I have pictures too.
