Mounting a Clothes Rod in the Shower |
Post Reply | Page <12 |
Deb & Sam
Newbie Joined: 07 Aug 2013 Location: United States Online Status: Offline Posts: 10 |
Topic: Mounting a Clothes Rod in the Shower Posted: 31 Oct 2013 at 9:36pm |
I saw your post duirng my original search. The dealer tells me there's nothing in the wall (no stud) to fasten to so I'm curious to know what you found. My pod has a hollow panel on one end that covers the wiring. The other end seems solid enough and I can probably find a stud. But how to handle the hollow end has me stumped. Can you tell I'm not handy? LOL
Deb
RPod 178 |
Posted: 31 Oct 2013 at 9:48pm |
There have to be studs, but worst case you can use molly bolts.
kymooses
Posted: 01 Nov 2013 at 4:34pm |
You don't need much to hold a few clothes on.
When I took off the factory rod the screws were not in any kind of studs nor did they use any molly bolts or anything. Just a couple of screws in the wall material seem to be fine to hold a clothes rod up with. Those panels are a thin wood sheet with the texture laminate covering over it. I'd wager it'd be as strong a hold as your drywall at home. If you had a huge concern about it still put a bit of foam tape between your mounting bracket and the screws. Let it be screwed and stuck both!
Deb & Sam
Posted: 01 Nov 2013 at 5:43pm |
Thanks for the advice. I'm going to tackle this install tomorrow. Wish me luck!
Deb
RPod 178 |
kymooses
Posted: 01 Nov 2013 at 9:17pm |
Piece of cake, you'll nail it! Let us know how your final install goes and what method you ended up using. And...we love pics!!!
