Parking my new Pod |
fwunder
Topic: Parking my new Pod Posted: 12 Oct 2013 at 12:01pm |
We are really looking forward to bringing our new 178 home next Thursday!
While it will sit in our driveway for a few days as we study, I'm still determining a resting spot on our property. I could use some advice. How level should the pod be when storing? Obviously, I would chock the wheels but I'm curious if a slight incline fore and aft or side to side would be a problem. When storing on a grassy area, would you use wood (pt) or cement blocks or gravel beneath the tires? I'm sure I'll have a ton more questions when we get it. Thanks! fred
Posted: 12 Oct 2013 at 1:37pm |
I always store campers at an angle to force water off the top. Even with all of the pod's curves there are spots on top where water will puddle. In-camp I always level it side-to-side but keep it slightly nose down to ensure the shower drains properly (on the 171 the drain is forward, other models have it the other way around). Personally I never use anything under the tires but some people do. |
retiredtraveler
Newbie Joined: 30 Sep 2013 Location: Chicago burbs Online Status: Offline Posts: 24 |
Posted: 12 Oct 2013 at 1:42pm |
X's 2 on the angle thing. A couple/three inches higher on one side, and back to front, will give good drainage. I've only put something under the tires if I was afraid of a soft spot and thought the tires would sink into the ground. A piece of scrapwood under tires certainly wouldn't hurt for peace of mind.
Looking hard at a pod
2006 Jayco 1206 (pup) with slideout, shower,solar 2005 Nissan Xterra (probably going to new Nissan Frontier) Into hard-core hiking and biking |
Posted: 12 Oct 2013 at 4:36pm |
We park ours level and hooked up. We also have used ours as a guest room. I like it being level so when I go out to pre-cool the fridge, it's ready, rather than having to level the camper first.
Remember, like many things, there IS more than one way. |
fwunder
Posted: 12 Oct 2013 at 4:39pm |
Thanks guys. I'm sure I'm over thinking this and should just concentrate on enjoying our new guest house!
