  New Posts New Posts RSS Feed: Refrigerator Woes
Topic ClosedRefrigerator Woes
CharlieM View Drop Down
Direct Link To This Post Topic: Refrigerator Woes
    Posted: 11 Sep 2013 at 10:04pm
Direct Link To This Post Posted: 12 Sep 2013 at 10:29am
I found a 1.6 cubic foot model last night which claimed to use a compressor.  No amperage spec, but I remember using my Kill-A-Watt on my old dorm fridge a while ago and it wasn't much.  The fridge is now at my wife's work location so I can't test it again to get an exact number.
EmptyNesters View Drop Down
Direct Link To This Post Posted: 15 Sep 2013 at 6:17pm
I have found the Norcolds to be a much better product then the Dometic, I will be pulling out the Rpods Dometic and replacing with a Norcold. (Someday)
Goose View Drop Down
Direct Link To This Post Posted: 15 Sep 2013 at 6:37pm
We must be the odd ball....no issues to report, all has always been good with our frig and has always kept the stuff in the freezer frozen, even in AZ.   Goose
Direct Link To This Post Posted: 15 Sep 2013 at 7:51pm
+1,the only thing I would like to see is a little bit deeper fridge, the space is there.
dsmiths View Drop Down
Direct Link To This Post Posted: 15 Sep 2013 at 10:27pm
We are on our third season with the Dometic fridge. No problems so far. I did do something I normally do not do, I bought an extended 2 year warranty as my dealer said the 3 way fridge is about the only thing that causes a problem and could be a little expensive to repair. so far, so good. The extended warranty was fairly reasonable cost wise. I understand the 3 way fridges are rather expensive.
Dane and Donna Smith
2011 RP-172
lift kit
Direct Link To This Post Posted: 16 Sep 2013 at 8:54am
Yep, ours has been perfect. I have it on and cooling right now, turned it on Saturday afternoon, yesterday after church I threw my instant read in the freezer area and it was 10F, the fridge section was 34F in the crisper drawer.. We have noticed no difference in performance no matter the power source.
The fridge in the 'stream is nearly 40 years old, only two way, still runs perfect also. I did have to replace the door gaskets a couple years ago on it.
P&M View Drop Down
Direct Link To This Post Posted: 16 Sep 2013 at 1:48pm
I'll echo the last 4 posts ... 1 year in and not a single problem or issue with our fridge.
P & M ... and Comet too!
2012 171 -- The Monkey Pod
2018 Ram 2500
Direct Link To This Post Posted: 16 Sep 2013 at 8:34pm
 We too have had no problems all three ways the refrigerator works. I am presently using it on 110 volts all that is in the freezer is frozen solid. Twelve volts is the only way it will not operate the freezer at its best.  David and Danette
2014 Ram 1500 Quad cab
coopercdrkey View Drop Down
Direct Link To This Post Posted: 20 Sep 2013 at 11:51am
Many many thanks to Hogone!
I tried cycling the temp control and the fridge kicked in perfectly! I
could have made ice cubes in the little freezer section! Who knows why or
how this makes any sense, but apparently it works for the fridge's electronic
brain.
Bob and Joyce
RP 177 "Key Pod"
