  New Posts New Posts RSS Feed: Black water tank probes
Topic ClosedBlack water tank probes
Camper Bob View Drop Down
Direct Link To This Post Topic: Black water tank probes
    Posted: 18 Aug 2013 at 7:28pm
Once again our black water sensor is reading incorrectly.  I know we have a built in washer for the black water tank but it seems it is necessary to clean that tank out after each use, and then the probe may still not read properly.  Just did a search on the internet on RV tank probes and ran into a very interesting probe.  It is called the Horst Miracle Prob and can replace the probes in our gray, black and fresh water tanks, as needed.  The video fully describes why we all are having problems with incorrect readings and this Horst version seems to resist false readings because of the way it is designed.  Replacement seems quite easy and I'm wondering if anyone has replaced the original probes with the Horst version.  I may have to be the guinea pig on this, but these tank sensors are prone to false readings too often and seem to resist cleaning.  They are installed in the original holes of our sensors and just a wrench and screwdriver will be the only tools needed.  Cost of a pair is about $62.  Any comments?  Safe Travels.
Camper Bob and Camper Sue
2013 Rpod 171HRE(ORPod)
2016 Lance 1685
2015 Nissan Pathfinder
Direct Link To This Post Posted: 18 Aug 2013 at 8:13pm
I'll be interested in your tests.  I've considered adding a sight glass (clear vertical tube) on all three tanks.  Wouldn't be hard to piece one together with a few parts and would be accurate.
Sleepless View Drop Down
Direct Link To This Post Posted: 18 Aug 2013 at 8:33pm
I like your idea, but it seems like the sight glass tube in the black water tank could become plugged too easily.
Bob
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Direct Link To This Post Posted: 18 Aug 2013 at 8:49pm
Just eyeballed our sensor locations.  Our black water tank looks like it's nestled between two steel supports with lots of sprayed insulation.  Don't think its something that I could easily tackle and having the RV bandits lower the tank would be cost prohibitive.  Do however look up the video on the Horst Miracle probe.  Just what we need, only can't easily install them.  Safe Travels.
2016 Lance 1685
Direct Link To This Post Posted: 18 Aug 2013 at 9:08pm
Bob
Hmmm, well the top of the tube for the black tank could include a valve to flush the sight glass and the tank itself.
Direct Link To This Post Posted: 18 Aug 2013 at 9:49pm
  I found another tank monitoring system " SeeLevel " it has good reviews and mounts by what I understand to the outside of the tank. Perhaps it would work for the r-pods do not know the cost they could be expensive. David
2014 Ram 1500 Quad cab
Goose View Drop Down
Direct Link To This Post Posted: 19 Aug 2013 at 1:45pm
We had the dealer add the "Tornado" to clean the black tank before we brought the POD home, with the help of the "Water Thief" I always clean the tank before we come home. We have never really had any issues with false readings. Goose
Direct Link To This Post Posted: 19 Aug 2013 at 3:52pm
Using the internal cleaner usually works, but not always.  Maybe our diet is different.  Thanks for the input.  Safe Travels.
2016 Lance 1685
Direct Link To This Post Posted: 19 Aug 2013 at 5:49pm
My dad has been rv'ing for nearly 40 years. He says, and I quote, "when you see poop in the pipe, she's full"..
They have had everything from a VW Westfallia to a 53' DP. He says NO ONE makes a gauge that is 100% reliable.
coopercdrkey View Drop Down
Direct Link To This Post Posted: 19 Aug 2013 at 5:55pm
It's our gray water meter that shows "full" when we know for sure that it is
well under a quarter of capacity.  I figured it was just something we had to
contend with, but thanks for the idea and the link.  I will definitely look into it.
Bob and Joyce
RP 177 "Key Pod"
