Seanl ![]() Senior Member ![]() ![]() Joined: 19 Sep 2011 Location: Fredericton NB Online Status: Offline Posts: 633 |
![]() Posted: 26 Jun 2013 at 8:04am |
Hitting a curb is easy to do if you have not towed much before. It is easy to forget that the trailer turns tighter that the TV.
In the words of Mythbusters: Well, there's your problem!
Just saw on facebook that they hit a curb with it.
No Frigidaire owners forums but I did find a repair forum http://www.applianceblog.com/mainforums/forum40/
Curbs, sometimes a bad enough pothole at speed can damage them. That is the actual axle..
The hubs and spindles can be damaged by maladjusted/malfunctioning brakes, loss of grease, improper adjustment of bearings after a repack.. This particular axle and type of axle has been in use for a long time. It's what Airstream has used forever. (Edit.. Airstream has used Dexter torsion axles since at least '69 I KNOW for sure) There are 1000's of pods out there, the pod users are a pretty vocal/connected group, so you hear more about any problems. I would bet washing machines have a way higher problem rate.. but who belongs to the "Frigidaire Gallery Appliance Users Group"? |
I just looked at the pictures on facebook. Looks like damage not defective axle. Usually when you bend an axle on a trailer it is from overloading and the axle bows in the middle. The wheels will toe in at the top. I have had this happen to me. On this one the right side wheel is pushed back. I don't think that can be caused by loading. Maybe it hit a curb or something at speed. I would love to see a picture of torsion arm and the axle between the mount and torsion arm. I suspect that is where the damage is.
francoisfrogpod ![]() Senior Member ![]() ![]() Joined: 24 Feb 2013 Location: Missouri Online Status: Offline Posts: 109 |
Just read on the facebook page that another couple has a problem with a bent axel on the pod.This is the third such problem I've read about between the forums and facebook. What's with the axel on the pod? Anybody have a clue? Sounds expensive and dangerous.
Denny and Linda
2013 Pod 177 '08 Santa Fe |
