Bearing grease blown out into brake assembly |
Post Reply | Page 12> |
Author | ||
Bill-GA
Senior Member Joined: 13 Jan 2012 Location: Cumming, GA Online Status: Offline Posts: 214 |
Topic: Bearing grease blown out into brake assembly Posted: 26 May 2013 at 8:54pm |
I got my passenger side jacked up and when I took off the wheel it was LOADED with bearing grease ... on the parts, inner hub, brake pads! Rear seal was full of grease on outter side. I cleaned the elec pad and post before taking pix.
I know I need new seals, but the bearing looks good as far as I can tell (not burnt).... Heres what I need help with ... PLEASE offer suggestions... 1. I think I'll have to disassemble brake parts to clean - I've done this MANY years ago. ... WHAT DO I USE TO CLEAN them? 2. The brake pads are soaked in grease too ... CAN THEY BE CLEANED? or should I replace? 3. Should I go to a pro? This could be pricy$$$$ I pumped the zerk fittings with grease early last summer ... one side took a while (it was probably me that pumped grease into brake . Amazingly I went to Maine (1300 miles) and back ... no problems noticed???? I've manually applied brakes with controller to make sure they work MANY times. Hmmmmm, I thought grease binds the wheel when brake is applied? I'll have to check them out when repaired. |
Bill & Bev
13 yr old dachshund 'Elsa' 2010 RP-176T (tent & slide-out) 2011 Toyota Tundra 2WD TV |
Anthony Valenzano
Groupie Joined: 09 Apr 2013 Location: Archbald Pa Online Status: Offline Posts: 44 |
Posted: 26 May 2013 at 8:59pm | |
Go buy Super Clean at an auto parts store. Spray on let soak for 10 minutes hose off - it will rip thru that grease. May have to do it twice. I don't think you'll even need to take it apart.
Foaming engine degreaser might work really well too. Have you been pumping grease into the zerk fitting? -- Sorry just read the last line - yeah those Zerk fittings are best ignored. |
Craneman
Senior Member Joined: 12 May 2013 Location: Tokeland,wa Online Status: Offline Posts: 387 |
Posted: 26 May 2013 at 9:28pm | |
I just replaced my bearings and seals,and I asked the mech at the rv repair about using the grease zerk and he recommend the I not use it. Result would be what you have. Repack once a year with new seal.
Just a thought Moe
Outbound
Posted: 26 May 2013 at 10:21pm | |
The brakes are pretty simple and parts are cheap. Just use some aerosol brake cleaner and wipe down with paper towels; it'll clean up fairly easily. Personally, I'd go with new shoes (although there should be nothing wrong with just cleaning up the old ones) - and I'd probably do both sides.
I never did like that zerk fitting, where the grease comes out under the inner bearing or the fact that the process pressurizes a void with grease, and I've never been sure where grease pushed though the inner bearing is supposed to go... but I know that others swear by regularly squeezing grease into the zerk fitting. A yearly inspection is recommended by Forest River and the axle manufacturers. Personally, I repack the bearings and replace the seals annually, but that may be overkill.
Bill-GA
Posted: 27 May 2013 at 9:27pm | |
Thanks guys for you comments ... I'll be doing the brakes and repacking bearings with new seals in a week or so. Bill
Bill & Bev
Bill-GA
Posted: 04 Jun 2013 at 8:51pm | |
I did the brakes this AM. I had to disassemble the brake with the grease blowout - grease all over the place. It took 2 cans of brake cleaner in total - great stuff. I used a large plastic bin underneath to catch droppings. I also used a purchased seal remover ... really good idea as bearing hub was lower than wheel hub and would not accommodate large screw driver.
I also bought a grease packer http://www.amazon.com/gp/product/B0002NYDYY/ref=oh_details_o00_s00_i01?ie=UTF8&psc=1 but I'm not sure I used it correctly - which side of bearing goes down? ... Hand packed it anyway. Any suggestions for future correct use of packer? I saw that I have manually adjusted brakes ... So I adjusted them while wheel was raised. I tightened adjusting star wheel until wheel held firmly, then backed off 6 clicks - saw that in an online video - sounded good? I tested them by spinning wheel and then applying brakes via manual brake controller lever. These brakes should work way better than they were. I will road test tomorrow.
Bill & Bev
bhamster
Senior Member Joined: 19 May 2011 Location: Washington Online Status: Offline Posts: 165 |
Posted: 05 Jun 2013 at 9:53am | |
I bought the same one when I repacked mine. The bearing can probably go on either way, but I used it with the wide part at the bottom and it worked well. You'll still end up with a glob in the middle which I just picked up with my (gloved) finger and packed into the races.
Outbound
Posted: 05 Jun 2013 at 5:51pm | |
like bhamster said, wide side down.
That's a bit further than I tend to back them off. But, you can always adjust them a click or two while the wheels are on the ground now that you know how its done.
Bill-GA
Posted: 05 Jun 2013 at 9:05pm | |
When I used the packer I was expecting the grease to ooze out from around the actual bearings but the grease typically came out the top or the bottom of the bearing. I saw this too on the video I watched. I guess this is normal?
Bill & Bev
bhamster
Posted: 05 Jun 2013 at 9:46pm | |
I gave mine a spin and then a couple more pumps. Then slathered around the outside. The part it helps with is filling the voids inside.
