  New Posts New Posts RSS Feed: Battery Charging
Topic ClosedBattery Charging
Thinker View Drop Down
Direct Link To This Post Topic: Battery Charging
    Posted: 06 Mar 2013 at 9:25am
My pod is in my barn where I have full hookups..  If I leave it plugged in will the battery overcharge and boil the water out?
On my Motorhome, I had to use a battery minder, 2amp trickle charger as the inverter did not charge the coach batteries, only the house batteries.
Direct Link To This Post Posted: 06 Mar 2013 at 9:29am
No, the pods charger has a built in battery tender.
Direct Link To This Post Posted: 06 Mar 2013 at 9:37am
Nice, thanks.  So I don't have to worry about the battery boiling over if I leave it plugged in all the time.
this_is_nascar View Drop Down
Direct Link To This Post Posted: 06 Mar 2013 at 1:36pm
Leave it plugged in all the time.  It will be fine, however you should still check the battery water levels every 30-days or so.
"Ray & Connie"
- 2017 R-Pod RP-180
Direct Link To This Post Posted: 06 Mar 2013 at 10:19pm
What they said.  It has a great 3-stage charger built in so you'll be fine.
TrinityTurret View Drop Down
Direct Link To This Post Posted: 08 Oct 2013 at 1:03pm
If I get one of these simple $3 15 amp RV female to 30 amp male adapters...can I plug in to household AC power and then charge/tend my Rpod 171 battery (using the pod's built-in inverter/converter thing)?
http://www.campingworld.com/shopping/item/15-amp-rv-female-to-30-amp-male-adapter/69605
There's only one way...
Direct Link To This Post Posted: 08 Oct 2013 at 1:39pm
Not with that you can't. You need a 30amp female to 15 amp male adapter
http://www.campingworld.com/shopping/item/30-amp-rv-female-to-15-amp-male-adapter/69604
Then, yes you can.
Direct Link To This Post Posted: 08 Oct 2013 at 1:42pm
:) Thanks...LOL, Learning here... Big smile
kymooses View Drop Down
Direct Link To This Post Posted: 08 Oct 2013 at 9:23pm
We all learned a thing or two here!  Smile
