  New Posts New Posts RSS Feed: Anode Rod Socket size
P&M View Drop Down
Post Options Post Options   Quote P&M Quote  Post ReplyReply Direct Link To This Post Topic: Anode Rod Socket size
    Posted: 26 Nov 2012 at 11:03am
When winterizing yesterday afternoon I was able to do everything but one thing, which was to pull the anode rod so the H2O heater could drain fully.  Try as I might I could not get it to budge with the limited amount of room to get a wrench in and on it, and I did not have a large enough socket to fit onto it.  I need to go and get a socket for it so I can swing by tonight, pull it and drain the tank to finish off everthing, and did a search on here where it appears that the size of the rod is 1 & 1/16th of an inch.
Can anyone confirm if that is the correct size socket I need to buy?  Thanks!
P & M ... and Comet too!
2012 171 -- The Monkey Pod
2018 Ram 2500
Post Options Post Options   Quote marwayne Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2012 at 12:04pm
That is correct,
Post Options Post Options   Quote techntrek Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2012 at 4:33pm
If you drained using the low-point drains - and opened the over-pressure valve to break the vacuum in the water heater tank - it will be fine.  I only pull my anode rod every couple of years, the other years I do it like I just described.  I've done this on my old popup and the pod without issues.
Post Options Post Options   Quote furpod Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2012 at 10:34am
Yeah.. but everybody needs to pull that anode under pressure at least once in their lives..
TIDALWAVE View Drop Down
Post Options Post Options   Quote TIDALWAVE Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2012 at 11:13am
I pull the anode rod every fall to drain the hot water tank when I winterize the Pod's plumbing. I have noticed that the anode usually has some magnesium loss where the magnesium touches the rod 'bolt head'. I believe that the acidity of the water that is in your tank makes a big difference in rod loss. Last year I found much more rod loss than this year...camped in different parts of the US.
I usually replace the rod before all of the magnesium is gone. Years ago I left a rod in and the end of the rod broke off in the tank because the central wire was the only thing holding the remaining magnesium to the bolt head and the wire broke.
TIDALWAVE
rudyunknown View Drop Down
Post Options Post Options   Quote rudyunknown Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2012 at 11:02am
If i want to replace the anode rod, do i have to replace the whole thing (bolt+anode rod)....also where do i buy them from?
2011 Rpod 171
Tundra
Rudy Reshmi n big Omkar n lil Arjun
Seanl View Drop Down
Post Options Post Options   Quote Seanl Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2012 at 12:22pm
MarkKevin View Drop Down
Post Options Post Options   Quote MarkKevin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2021 at 9:29pm
I purchased a suburban anarod and received from Amazon a PN 233514. I’m not sure they sent me the correct one. Will this one work?
Thanks
Mark
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2021 at 5:36am
Mark,
Yes , it will.  We must have the perfect well water as our anode looks nearly new even after 10 seasons and the water is kept in the water heater from May thru October every year.
Post Options Post Options   Quote MarkKevin Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2021 at 9:38am
Thank you
Mark
