Sort-of Antenna Review |
Post Reply | Page 12> |
Topic: Sort-of Antenna Review Posted: 30 Nov 2012 at 11:09pm |
Another note on it using 12 volts, if you are bookdocking make sure you turn it off when not in use.
bhamster
Senior Member Joined: 19 May 2011 Location: Washington Online Status: Offline Posts: 165 |
Posted: 30 Nov 2012 at 1:03pm |
Yeah, it's the same in the 171. It's also worth mentioning that the amplifier has 12V power, which makes it super-easy to put in one of these instead http://www.amazon.com/Winegard-RV-7042-White-Plate-Supply/dp/B000GGL4CG and get an extra 12v outlet.
marwayne
Posted: 29 Nov 2012 at 4:18pm |
The amp switch is in the cabinet above the cooktop in the 172, I tkink it is the same in the 171.
P&M
Senior Member Joined: 13 Aug 2012 Location: Spokane, WA Online Status: Offline Posts: 454 |
Posted: 29 Nov 2012 at 3:14pm |
A pre-amp button? And it isn't on the unit itself, but somewhere near the plug? Don't recall seeing one but will write this down in my log book so that I can look for it the next time I swing by the storage lot. That would definitely explain why I wasn't getting any channels ... thanks!
P & M ... and Comet too!
2012 171 -- The Monkey Pod 2018 Ram 2500 |
Posted: 28 Nov 2012 at 6:37pm |
Also check to be sure that the coax cable connectors are tight. On mine one was so loose that it fell off when I touched it. Not good for reception.
It still is what it is. We didn't get ours for TV watching. |
Paige
podders Helping podders - pHp Joined: 23 Jul 2012 Location: Upstate NY Online Status: Offline Posts: 216 |
Posted: 28 Nov 2012 at 4:31pm |
Found it! Could explain why the tv didn't pull in any channels,,,not that we really cared to watch. Thank you!
Paige and Pete
2010 177 - RPug 2012 Rav (six cylinder) New York & Florida residents |
Posted: 28 Nov 2012 at 9:11am |
It is in the box that the TV is mounted to. Open the door and you will see it with the antenna cables coming to and from it. It has an led that is also a push on/push off switch.
Paige
Posted: 28 Nov 2012 at 7:46am |
There is a preamp? Where is it in the 177?
Paige and Pete
Posted: 27 Nov 2012 at 7:32pm |
The skin on the roof is fiberglass and shouldn't cut down the signal much. I think the frame is aluminum and that could.
I am not into the TV much, but when I have had the amp on (and most of our first year I didn't know it was turned off) I got fairly good reception. If I had the choice I would have opted out of the TV/Antenna and saved the money. We looked at three 177s when we got ours (at two dealers). Two were alike with all the options. One was stripped completely (no TV, no microwave/convection oven, no air conditioning). WE may have taken the stripped on if it had air, but we sweated out to many nights on the plains in the summer to do that. To each their own I guess. |
dsmiths
Senior Member Joined: 10 Oct 2011 Location: Southern Ind Online Status: Offline Posts: 866 |
Posted: 27 Nov 2012 at 7:30pm |
P&M, make sure the preamp is turned on, there is a small green led light that shows its on, if not you will get poor to no reception. On our 172 its in the cabinet above the stove.
Dane and Donna Smith
