Front bike rack and tounge weight |
Post Reply | Page 123> |
catspaw
Newbie Joined: 06 Oct 2012 Location: Minnesota Online Status: Offline Posts: 9 |
Topic: Front bike rack and tounge weight Posted: 27 Mar 2014 at 8:44am |
The advantage of the Arvika is being able to fold up the tray rack to access the batteries and LP tank. Also, makes more room for the 30W solar panel that mounts on the jack. We also purchased the 2" receiver mount for the Arvika so we can put it on the TV for side trips or our Outback for day trips at home.
RPodWeGo
Senior Member Joined: 10 Jul 2012 Location: Salt Lake City Online Status: Offline Posts: 112 |
Posted: 20 Mar 2014 at 12:46am |
More pics please
RPodWeGo
RPod 177 04 v8 Toyota 4Runner |
venture230
Newbie Joined: 17 Mar 2014 Location: Idaho Online Status: Offline Posts: 6 |
Posted: 19 Mar 2014 at 11:25am |
Needed to carry Bikes - Goal is to carry four - two on rear - two on front. Half way there!
We have the Thule tray racks (2" hitch mount and the 2 bike add on). I bought steel to mount the 2 bike add on to the fron of the trailer. In the future the 2" rack will go on the back and the spare tire to the front. 2014 R172 The clamp-on racks are expensive. Metal, not so much. Go find a welder you trust! :)
betsypgarmy@yahoo.co
Newbie Joined: 02 Jun 2012 Location: Nebraska Online Status: Offline Posts: 19 |
Posted: 26 Jun 2013 at 10:47am |
Thank you for the Bike Ideas!
bhamster
Senior Member Joined: 19 May 2011 Location: Washington Online Status: Offline Posts: 165 |
Posted: 26 Jun 2013 at 10:15am |
Sorry, only bikes with 9 speeds or fewer Seriously though, it should fit fine but make sure to pad it so that it doesn't bang up the cabinets.
Posted: 26 Jun 2013 at 9:17am |
Must be, we carry our tandem in it sometimes. No reason a single won't go. Though I do note we have to load/unload with the slide out. |
Paige
podders Helping podders - pHp Joined: 23 Jul 2012 Location: Upstate NY Online Status: Offline Posts: 216 |
Posted: 26 Jun 2013 at 8:24am |
Yes it is! We have a 177 and we carry two bikes. The first bike we put in goes toward the back. It fits just fine. The second bike fits alongside the table. Our table is able to be slid over right up against the bench on the door side as we have two holes in the bench and we slide the two table legs into the bench area, giving us more room on the other side of the table. We have been RV'ers for a while and always had our bikes mounted on the outside. When we bought the rPod, we discussed trying to figure out a bike rack, but decided to put them inside for the time being. Eventually we might add a bike rack to our tow vehicle,,but we usually have kayaks up there. The nice thing is that the bikes are protected from the weather and the road grime. The not so nice thing is that if you want quick access to the rPod while on the road, you have to take the bikes out. We added some heavy duty hooks inside the rPod and bungee the bikes so they don't rock and roll while we are on the road.
Paige and Pete
2010 177 - RPug 2012 Rav (six cylinder) New York & Florida residents |
Posted: 25 Jun 2013 at 10:56pm |
Is it possible to carry a 10 speed bike inside an RPod 177?
Posted: 18 Jun 2013 at 1:07pm |
Very nice, and good use of the empty space above the tongue.
MTB Pod
Newbie Joined: 30 Aug 2011 Location: Sacramento, CA Online Status: Offline Posts: 9 |
Posted: 18 Jun 2013 at 10:49am |
After seeing the posts on the Avrika tongue mount bike rack on this site this last year, I forwarded it to my dad who does welding to see if he could fabricate something for us. He was able to make a bracket that would accept two Yakima bike holders that are part of an extension for a four-bike hitch mount rack. I didn't want it to be permanently welded to the frame, so he was able to make solid brackets that bolt it on to the frame. This way, if we need the four-bike hitch rack, we can pull the two holders from the Pod and reattach them to our hitch rack. We finally had a chance to use it this past weekend, and it worked great. It is extremely solid and does not move or flex independently of the trailer frame.
The added bonus is that because 99% of our camping is dry camping, we usually fill our fresh water tank prior to leaving the house. With the 177, the fresh tank is located behind the axle (which has been my only complaint with the Pod so far). Despite the fact that we tow with an F-150, we would still get sway with a full water tank. The extra weight of the rack loaded with bikes had exactly the effect I was hoping for, in that we had zero sway with a full fresh water tank, and that was with fairly strong winds headed out through the Columbia River Gorge. |
Pete & Marila
Sacramento, CA 2012 RPod 177 2001 Ford F-150 Crew Cab |
