  New Posts New Posts RSS Feed: New - Rpod 178
Topic ClosedNew - Rpod 178
Direct Link To This Post Topic: New - Rpod 178
    Posted: 05 Oct 2012 at 7:32pm
Hot off the presses, apparently.  I went to FR's website to check on the dimensions of another pod and noticed a little yellow "New" next to a model number I hadn't heard about.  So I clicked on it to see the specs... no specs!  It is so new FR doesn't even know yet.  But they do have the floorplan up.  Appears to be like the 177 with the queen and slide-out, but with a full U-dinette.
http://www.forestriverinc.com/LiteTravelTrailers/rpod/default.aspx?model=rpod&page=floorplandetails&floorplanid=4882&RVType=LTT
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 05 Oct 2012 at 9:21pm
And entertainment center up front instead of that tv thingie over the bed.  Interesting.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Paige View Drop Down
Direct Link To This Post Posted: 06 Oct 2012 at 7:00am
Finally, they got smart with the entertainment center!!! Wonder how long the dinette table is.
Paige and Pete
2010 177 - RPug
2012 Rav (six cylinder)
New York & Florida residents
coopercdrkey View Drop Down
Direct Link To This Post Posted: 06 Oct 2012 at 10:56am
On my monitor, the distance from the end of the trailer to the "ST" designated point is 6".  That appears to me to be (approximately) the length of our 177, and would scale to about 3' per inch.  If so, the new floorplan comes in at 21'.
Hmmm.....
Seems like the GVW and tongue weight may be pushing the envelope of some of our popular TV's, but I guess we'll know when the factory spec's are published.
Bob and Joyce
RP 177 "Key Pod"
Direct Link To This Post Posted: 06 Oct 2012 at 11:00am
That would make it out of our TV's comfort zone!
Paige and Pete
2010 177 - RPug
Direct Link To This Post Posted: 07 Oct 2012 at 9:12am
I see the "PT" points, for 'pass through, I assume, at the same location as our 177, but the "ST", for 'storage (?)', looks like outside access to the area under the dinette seat.  Boy, do I wish that were the case in the 177's.  What a convenient place for the set-up items!
Bob and Joyce
RP 177 "Key Pod"
Direct Link To This Post Posted: 17 Oct 2012 at 5:40pm
Many of the specs have now been posted:
Dry Hitch Weight 257 lbs. (117 kg)
Unloaded Vehicle Weight 2,535 lbs. (1,150 kg)
GVWR TBA (TBA)
Cargo Carrying Capacity 1,222 lbs. (554 kg)
Exterior Length 20' 0" (6.1 m)
Exterior Height 9' 7" (2.9 m)
Exterior Width 96" (2.4 m)
Fresh Water Capacity 36 gal. (136 L)
Gray Water Capacity 30 gal. (114 L)
Black Water Capacity 30 gal. (114 L)
Awning Size TBA (TBA)
Podsible Dream View Drop Down
Direct Link To This Post Posted: 17 Oct 2012 at 6:29pm
Getting up there- like a 181 in size! I can't say that I like the door swing on the bathroom. If it was the other side, it makes convenient dressing room area behind the door, likevon the 171. This way it opens in your face when you get out of bed.
Chris and Walt
'10 RP-171 'Free Spirit'
MTB Pod View Drop Down
Direct Link To This Post Posted: 17 Oct 2012 at 7:01pm
The door opens that way on the slide-out versions so that you can access the bathroom when the slide-out is in.
Marila
Pete & Marila
Sacramento, CA
2012 RPod 177
2001 Ford F-150 Crew Cab
Direct Link To This Post Posted: 17 Oct 2012 at 9:03pm
Our door in the 177 swings like that,,,you can get into the bathroom when the slide is in,,,like when you are traveling. Also, if someone is at the dinette and someone sleeping in the bed, having the bathroom door opens provides some darkness and privacy to the sleeper. We added a curtain to do that too.
Paige and Pete
2010 177 - RPug
